Time Tested Network Operations Solutions: 101 - 119 of 119
OK, I have a network with several vlans each vlan has its own subnet in our one dhcp server, The switches are cisco 3500 series and they are connected to a cisco 6006 via fiber. I understand t...
What are the ramification to raising the Forest Functional Level from Windows 2000 to Windows 2003?  I only have Windows 2003 servers.  Is this change immediate?  I understand I cannot change ...
My client has a small network of appoximately 30 workstations.  IP addresses are assigned by DHCP and have been for several years.  The workstations are an assortment of Windows 2000 Pro, Wind...
When do you want to use one and the other? What is the difference and pros and cons?
Hi. I initially had a problem trying to access this PC at all from my laptop over the wireless network, but after tons of searching, I found an answer. Now my problem is that if I try open ...
Heres the config from a Cat Switch - theres a firewall plugged into FE01 - and the two vlans represent two DMZ's The firewall is "multi homed" on the other end of FE01 and has an IP address i...
I have a network running SBS 2003 and XP clients. We have several apps that rely on security tokens and mapped network drives to function. I need to set up a PC at a remote location. Can I joi...
Guys i have radus (802.1x authentication) setup on my network but here is the question what do i do about printers how do i authenticate those ports using radius preferrably.  If i cant use ra...
I don't know how to make this more concise. We've been having real trouble with our VPN Tunnel. I have a Cisco ASA 5510 at each end and everyone who has looked at them say they are configured...
Do you have any ideas I can use. This one is killing me. I have a vendor who has equipment throughout my network and everything is fine but one device. I can't see it on the network. I can p...
Hello, Got a question, I just set up a Cisco home Lab to practice for CCNA, as most everybody got a 2509 to serve the purpose of a console server for the 2501 and other eq in the lab.  My 250...
FIrst thing, my cisco knowledge on a 10 point scale is a 2. Anyways I have a switch on the far end of the buidling that no one really uses.   We have a trainging center that has a wirele...
We have network for about 2000 computers supported by Cisco Catalyst Switches, The issue is with the users, Most of the users need to do a release and renew for the IP to get the access to in...
Looking for recommendations for what logging level to use on our Cisco equipment (i.e. 4- warning vs 7- debug) with an eye on Security.  How much is too much, or not enough, when using a log c...
I have created VLAN on HP 2650 Switch. Our default network is 172.50.200.0/21. The devices on this new VLAN will be manually assigned addresses in 172.50.192.0/21 space. The switch has 172.50....
As you no most switch come configured with ports in dynamic mode and you have to put them in access mode if you want them to be.  What i want to know is when i run the switchport mode trunk co...
I'd like to export MAC address and ARP data from Cisco and/or 3Com switches/routers into a  database to create an IP to port mapping.    I'd like to be able to automate the export via some typ...
Having a very annoying issue with Orion Network Performance Monitor.  I've been on the phone with both Dell and Orion and this is where I'm at right now: Created a custom MIB Poller using O...
What is the most proper reason to have multiple loopback interfaces configured for a single device, preferably in routing ?
