I need to run a script/ batch file to wake up (WOL) several hundred PCs ( DELL gx150, gx 260, gx 270 gx 620 - mostly Windows XP) in the middle of the night.
First - the script needs to enabl...
I am looking for job in UK as a network engineer OR IT support andI have created a CV after a long research because its come in to my knowledge that its very important to find a job that the p...
I'd like a way to test my internal network speed at work. I've tried various software in the past but they have been sketchy at best. Any know of an easy to use program or simple method or tes...
I am using .bat files for sartup scripts to connect network drives, and I just recently started getting this error when I try to run the scripts on login.
System error 64 has occurred. The...
Delivery has failed to these recipients or distribution lists:Only to comcast.net
Hi, I am trying to block facebook on my home network - but i want to leave a "back door" way to access the site for myself (or someone I tell how). Here is my network setup (indentations mean...
Got a real problem here that I can't resolve. Windows Vista Home machine with wireless adaptor can no longer connect to wireless network. Customer tells me that the machine was on the wireless...
hello.
I've encountered a problem when we transfer large files,
It can be internally in the server between the Internal HD or to or from the server,
the system crashes and often a bs...
The laptop is asking for the bios password.
While I was installing Hamachi, it wanted me to rename my Hamachi Adapter to just Hamachi, I couldn't complete this step because the adapter wasn't available. So I created it manually. The com...
I have a network of about 10 workstations running windows xp, logging onto a windows 2003 server. Im getting an error message every now and then on some of the workstations.
From the works...
We have a main site with a flat 192.168.1.X network. All the PC's use a Windows 2003 DHCp server to get thier IP. They all point to our Cisco ASA5510 as the default gateway.
We a...
Hi Experts.... Please help
I am using a Small Business Server 2003 with exchage. I am trying to set up an auto resonder to automaticaly respond to emails sent to jobs@mydomain.com. I have the...
i've installed Wireshark for network protocol analyzer.
I wish capture all network traffic of computers on my switch, but Wireshark offer me only my network interface for capture??
IS t...
Dear all expert! I've built my virtual LAN with 3 guest OS list as below,
Windows 2003 Standard - Domain controller
Windows 2003 Standard - DHCP
Winxp Pro Sp2
All these guest OS connecte...
Does anyone know of a good side by side comparison of Kaseya, LevelPlaforms, N-Able
I use a login script to map network drives.
"Remove mappings
oNet.RemoveNetworkDrive "I:"
oNet.RemoveNetworkDrive "K:"
oNet.RemoveNetworkDrive "L:"
oNet.RemoveNetworkDrive "M:"
oNet....
Need help to unlock a laptop which one of our pupils has locked with the bios PW. Laptop is a Dell 531 with tag B24KR3J-595B.
Any help would be appreciated. Thanks
Title says it all really. I need to connect to D-LINK DIR 635 routers wirelesly. To add to it want to say that I have read all the manuals, FAQ's etc. wireless bridging is not mentioned a...
I have to upgrade the firmware on a Dell Poweredge 2900 so I have some "newbie" questions:
* I am told I can flash the BIOS via a virutal floppy / USB key. If so ho can this be done....
I need to create a small iSCSI network using existing Switches, everything is in place, however I would like to implement Jumbo Frames on the iSCSI LAN. I Have 4 Cisco 48pt 2960G switch...
I have 2 Cisco asa 5520 series routers. They have been used for testing and need to be reset to the factory settings. I have tried a few things, but have not been successful. I can concol...
Hello
One a my clients has a four LANS that soon will be connected. He need a profesional utility to view these Lans from the IT office. The main issue the he wants to have detailed reports...
good day
KIndly refer to my attached network topology of the site
the network topology consists of 3 sites connected to each other via serial micorwave links
the tasluja site is responsible...
I'm having a bit of an issue with snmp. I'm tryin gto get temperature info from a HP blade enclosure and I got the mib files containing the necessary OIDs from the management disk that ...
