We have an IPCOP box with two Zones, GREEN and RED. The RED interface has an Public IP address and connects directly to a router and out to the Internet. The GREEN interface connects...
I have students logging into roaming profiles from client computers. They are loaded with nothing special and it seems to take more than just a couple of minutes for the personal profile setti...
A while back, I found an article on how to set your network drive through DOS so that certain applications think that it is the physical drive (or drive letter is an actual drive) and let you ...
I'm considering making use of SNMP to start monitoring the status and health of my network at work.
I understand the basic idea of SNMP, i.e. that's it's a protocol designed to broad...
for connecting a head office to branch offices , which one is better vpn or leased line
I have a Windows 2003 server that had a memory leak with the LSTrayAgent.exe process. Normally this process uses no more than 10 MB, however a memory leak occurred with the process consuming a...
Ok, so when students at my school log onto the computers in the classroom for the first time they all have to go through the initial setup for internet explorer and for microsoft word. So I ...
Hi, I am trying to block facebook on my home network - but i want to leave a "back door" way to access the site for myself (or someone I tell how). Here is my network setup (indentations mean...
I am wanting to monitor a VMWare ESX Server via SNMP and need a little assistance with how vmware assigns the ID to vmVMID.
Scenario:
I do a mib walk to my ESX server and it returns VMWare...
i have 5gt netscreen firewall with os 4 on it. how do i upgrade to 5?
after installing SP1 for vista this morning i have found that some 2 of the 3 machines on my network cannot longer login to the domain. all i get is the message:
"The security database on ...
i need step and guied how to build msi package with WinINSTALL LE ?
Guys, and blazeking if you're out there, I would like to try out iperf to test my network's internal speed. Any help without how to install and utilize this tool would be great. When I downl...
Currently we have about 40-50 employee's and 20 or so are sales executives. Everytime they want to use a different computer I must go that that workstation and setup their Exchange and other i...
How to activate Password expiration reminder for remote users (over VPN) in Active Directory/Windows Domain.
i want to deploy exe file (FileFormatConverters.exe)to all computer in my network but without involved from the user its mean when the user open the computer the file install automaticly how c...
When I boot my router, it does not have any of my saved config. The config is in the CF card and I can even do a copy start run and all of the info is there. It just is not there in the runnin...
I'm reading a book right now about Network+. Not sure if I understand what they're saying. It says that data moves down a one-way path with a ring topology. And if the topology has a break ...
hello.
I've encountered a problem when we transfer large files,
It can be internally in the server between the Internal HD or to or from the server,
the system crashes and often a bs...
Has anyone found a reliable and effective setup for N-Able monitoring of VMWARE ESX servers?
Syslog is not working as I want it to. I need to monitor the ESX systems as well as I can every...
My network is running very slow at certain times and not others (slow downs can last all day, or just 4 hours at a time). I am very new to diagnosing network problems, and my network is comple...
I'm having problems getting my T1 connection up and could use some advice...
I have the following:
1. Two brand new Cisco 1841's each with a dual port T1 card in slot 1. (not a CSU/DSU com...
Hi every1
I'm looking for any solution how could I run remotely vbs script on computers within domain using delphi of course. I don't know if I should copy vbs script to every workstation ...
Are there any applications out there that can block access to the internet over a network. So from me PC i can block access to a certain computer on the network. I found Internet Access...
2000 Ad domain and as Admin I'd like to temporarily remove the users 'restricted' policy when they need assistance.
I used to use a small app called 'Polkill' with Win 98 end users but can...
