after installing SP1 for vista this morning i have found that some 2 of the 3 machines on my network cannot longer login to the domain. all i get is the message:
"The security database on ...
Hi every1
I'm looking for any solution how could I run remotely vbs script on computers within domain using delphi of course. I don't know if I should copy vbs script to every workstation ...
I have a number of cisco switchs (3560) and connecting all these I have a 3750. I have 4 VLANs and have set up trunking between the core and the 3560, but now I'm going to need to enable inte ...
I replaced my print server with dlink DPR-1260, the other one quit. So far there has been no problem printing from any windows program that was an easy setup. I ahve a couple dos oriented pro...
Please, let me know step by step, how to configure vlan on a 3500 XL cisco switch.
It has 24 ports, i want ports 0-15 on vlan 1 with ip 192.168.0.1 and ports 16-23 on vlan 2.
Ian
Hi All,
I have network device ( Hardisk), I know the mac address for this device, I m unable to get the IP for this device, I checked the DHCP but I can not find the mac address in my DHC...
I have installed a bigger hard drive into our server because of limited space. The original home folders were located on d:\home with a share name of "home". The new drive is G:. If I wanted ...
I have a small network consisting of the following
File Server: HP DL380G5 Proliant - Operating System Windows Small Business 2003
Phone Server: 3COM NBX V3000
Intern...
Hello, I just need a reccomendation. We have a terminal server in one site and a file server in another site separated by a router. I wanted to know what would be the best free program to mo...
Hi I have a few IP addresses from the Philippines. I have traced them using ip-address.com.
202.69.178.197 This shows as Davo City
202.69.188.253 This also shows as Davo City
2000 Ad domain and as Admin I'd like to temporarily remove the users 'restricted' policy when they need assistance.
I used to use a small app called 'Polkill' with Win 98 end users but can...
Are there any applications out there that can block access to the internet over a network. So from me PC i can block access to a certain computer on the network. I found Internet Access...
Can someone help me out here. I'm kinda new to all this...
I want to auto run a command to copy the hosts file from the server to the user's computer when they logon to their account on the n...
I am using .bat files for sartup scripts to connect network drives, and I just recently started getting this error when I try to run the scripts on login.
System error 64 has occurred. The...
I'm reading a book right now about Network+. Not sure if I understand what they're saying. It says that data moves down a one-way path with a ring topology. And if the topology has a break ...
Hello Everyone,
I am trying to figure out how to update our ERP software package (Blackbaud) on our systems that don't have rights to install software. Unfortunately, Blackbaud has patches ...
I have 2 computers and a HP Photosamart 2575 printer on a 10/100 network.
The internet comes into a DSL modem which is connected to a 5 port Dynex switch. Also connected to the switch are t...
I took home from my office my xw8000 (Windows XP) workstation. It was connected to a network with a windows domain using Small Business Server. I wanted to use it in a work group configurati...
My user community is no longer able to browse our domain. Users click on Entire Network and it takes about two minutes to list ONE domain name, which is our DOMAIN. When they click on the Do...
Hello All!
I just segmented my firewall interfaces. Here is my config.
192.168.1.x (Green)
192.168.1.5 Syslog Server
192.168.2.x (Blue)
192.168.2.2 (Blue Router)
Now I want to sen...
I just upgraded our CiscoWorks LMS 3.0 server to 3.0.1 (Dec 2007 update). Running on Windows Server 2003 Standard R2.
Now I can't access it at all! It appears that the Windows servic...
Im trying to setup my Nagios system so that when specified services fail it can shut down my Windows 2003 Server. I figure I can do this with a script of some kind, but I have no idea where ...
I seen that my network engineers adding route and gateway to routing table( Both linux and windows)
Why they are doing that. In what circumstance they will do that?
I know routing table is f...
I've got a WAP that's gone missing on a network I'm not in close geographical proximity to.
Is there a command line utility or software to scan the LAN for MAC addresses without getting i...
In a server 2003 AD with xp clients the user auth ok but the profile loads very slow. Xp running sp3 and all updates
