Time Tested Network Management Solutions: 76 - 100 of 240
I'm having problems getting my T1 connection up and could use some advice... I have the following: 1. Two brand new Cisco 1841's each with a dual port T1 card in slot 1. (not a CSU/DSU com...
I'm looking for tools to monitor bandwidth usage on both LAN and WAN.  I want to know who is using the bandwidth and what they're doing.  The only application I've ever used that meets these r...
When performing systeminfo on a remote computer in our domain, i get the error "ERROR: The RPC server is unavailable". Has anyone seen this or knows what is causeing this issue? Cheers
When I type nslookup at the command prompt it returns default server unknown.  I am trying to connect a new computer to our network and it says it cannot connect to the domain.  I have tried t...
I am looking for a tool that will document/map our LAN.  It contains about 10 Cisco switches, 1 router, and 10 terminal servers.  I know Visio will do the trick, but was hoping to use somethin...
I'm having problems with routing through my ASA 5510. I can ping the gateway and beyond from the ASA - 172.31.50.1 & 172.31.3.252 but I can't ping from the internal network through the dev...
I use Spiceworks for network management/inventory.  I believe it uses mostly WMI. I am ordering a bunch of new Dell computers. I have a choice of preinstalled: 1) ASF Basic Hardware Enab...
I have a W2K server on my network with the IP Address of 10.20.100.117 and a subnet mask of 255.255.255.128. When I go to My Network Places I can't see the computer. I can ping it and I can ac...
Hi    I haven't worked with HP openview before. Currently I am looking for some video training or intuitive training or podcast on HP openview network managment (especially for MPLS or VOIP...
Hey Guys, I havea c ouple of Cisco routesr, 2800 series and a 7200 series. I need to monitor bandwidth usage and monitor for packet loss to figure out how much bandwidth we are utilizin...
I configured my eth0 with a public IP address, but looks like the firewall of SUSE linux 10 is blocking it, how can I enable it from the command line ?   At the time I try to ping my server h...
I have 2 computers and a HP Photosamart 2575 printer on a 10/100 network. The internet comes into a DSL modem which is connected to a 5 port Dynex switch. Also connected to the switch are t...
Dear all,  I have this network with this design every thing is ok.  Issue is: -     I want install cisco firewall ASA 5505 between the router and switch with same design and vlan, hint: pleas...
Our internet connection is running slow and I would like to clean up unwanted traffic on my network. I have a T1 data connection connected and monitor by a Pix firewall intergrated with webse...
I would like to know how to connect to one of our VM linux machine by using putty ssh client. The private ip of the linux box 10.10.10.20 has a port translation on virtual ip 64.225.214.67:220...
I am trying to set up a netflow export on a cisco 1841 but I dont seem to be collecting any data from the serial interface.  here is the output from sh ip cache flow. Basically I am only se...
Hello, We have an IPCOP box with two Zones, GREEN and RED. The RED interface has an Public IP address and connects directly to a router and out to the Internet. The GREEN interface connects...
Hi every1 I'm looking for any solution how could I run  remotely vbs script on computers within domain using delphi of course. I don't know if I should copy vbs script to every workstation ...
I am wanting to monitor a VMWare ESX Server via SNMP and need a little assistance with how vmware assigns the ID to vmVMID. Scenario: I do a mib walk to my ESX server and it returns VMWare...
Hi, I have a Cisco IP Phone that doesn't have a dialtone although the display at the panel looks normal. I can even forward it to a mobile. I have done the following. 1. replace the phone...
I have a new comptuer on my network I cannot log into via VPN.  We have at least ten other computers, XP and VISTA, that logging into is no problem. We are using the computer names, not har...
my company use ciscoworks appliance and has admin and password set which we didn't know the password. somehow, we got into the ciscoworks server and found that some wierd name was set for loc...
Hi, I am using a KVM switch with multiple serves. I start to get the error message of "Out of range" on that kvm screen for some servers. But I am able to access them through remote access....
I have a file server that is a domain that students use for roaming profiles in a lab. Is there a way to set the students to use certain printers without having to login to each student and ad...
Hello, I am having a problem with the roamin profile of USER A loging into MACHINE A. I recently installed Nero and then uninstalled it. I reset the computer after the uninstall and trie...
