Ok guys there are two servers. Both with windws server 2000.
One of thoser server is Cisco CallManager and the Other server is Cisco Unity.
As you know recently the DST changes needed to...
Dear experts,
I understand that information to a network equipment can be retrieved via snmpwalk.
However the output information of snmpwalk is too huge, is there any way or commands such ...
Dear Friends
I have 4 computers and and a laptop hooked on a gigabit 3 com network switch with category 6 cables
All hardware tested well. Every computer has an IP in the workgroup.
I have a home network set up as 192.168.184.xxx. The router is configured as a DHCP server with IP address=192.168.184.1 and subnet mask 255.255.255.0. So far so good, been running fine for ...
I am stumped - I have a Windows 2003 Server Domain which is connected via T-1 to other company servers. Some computers have fixed IPs, some have their IP assigned by DHCP
Let's call the ...
I have a need to power down all PCs on the network (across two physical sites) that are still on after 10pm nightly.
There are about 40 PCs (out of 500+) that need to be kept on to run overni...
What i need to know is how to nat on cisco 4948 the ip nat no longer works and i think you need policy-maps now or something.
Can anyone recommend a good software package or appliance that I can use to centrally manage Cisco devices (switches, routers, firewalls, wireless, etc.)?
We have over 200 devices in locati...
Hello experts
Windows 2000 AD network
all HP / XP desktops (Mostly Intel 1000 nics)
Some Sun servers, HP, compaq
We have a lan with 15 servers, and est 500 desktops. all the network ...
I've been playing with this for awhile now and can't find where I can poll the hardware vars from. I am configuring our monitoring system, NerveCenter, and I have masks just fine. However, I...
I have a colo'd server with RAID 5.
Is there some software that would auto notify me if a drive failed so we would know to swap the spare?
The colo provider doesn't offer this service.
The ...
Small network running SBS 2000. Have my workstations named "W-x" where "x" is the number of the machine as purchased (1st workstation purchased was "W-1", 2nd one purchased was "W-2", etc). ...
We have a network with the following configuration:
1) Windows 2003 sbs Server with Dhcp (range 10.80.70.x)
2) Connected to Adsl router which gives internet access.
3) The network consist o...
I'm trying to figure out how to run a specific command on a remote pc over an ssh session. I can't run a script on that system. It has to be from windows.
I can use any ssh client that can ...
looking for Appliance based proxy server. I just want better reporting more than anything, but ability perhaps to shut down access remotely or even automatically.
Need: easy to manage. pl...
We are asked as a hosting company to provide ddos protection. Is there a per server software we can install also what reasonably priced hardware options are there? We already have an optional ...
Is there any free software for Windows that can monitor internet traffic, and allow me to set download/upload rate per application? Something similar like NetLimiter does (not the free version...
We have a SBS server (PDC, DNS, DHCP) with 2 NIC's
LAN IP: 192.168.1.10
Subnet: 255.255.0.0
Gateway: blank
DNS: 192.168.1.10
WAN IP: 192.192.1.11
Subnet: 255.255.0.0
Gateway:...
My anti spam server is rejecting mail from a specific domain because of their SPF record.
554 This server requires you to send from an IP address specified by the SPF for domain-name-replac...
I have a Windows 2003 server with two NIC cards, one (NIC#1) is connected to my local network with its own ISP (ISP#1) and the other card (NIC#2) is connected directly to my second ISP (ISP#2)...
Dear experts,
We're puzzled by our office network's behavior. After changing a few defective switches, our Internet connection would be blazingly fast in the morning, but around midday, it ...
Has anyone gotten MRTG working with Extreme Networks gear?
Are there any docs that you can point me toward?
I can't even RTFM because I can't F(ind)TFM for how to do it with ExtremeXOS.
I am looking for a piece of software to deploy for network monitorin at a client's site. Basically they are running out of bandwidth and they want to see what traffic over what protocols are g...
How does VLAN works in terms of security?
Or what should I work with, regarding the discussion below?
I have a DFL-800 that I'm about to configure for three networks. Maybe four networks...
Im researching a solution to eliminate network connectivity as a potential single point of failure.
We current have an MPLS network in place with AT&T which has had some recent issues. I was...
