the quastion is strage but i need to know if there is idea about the :
windows NT or server we can connect from clients each user have him own desk top
now all remote softwares share the...
Hi there;
Is there a simple software that monitors all the ports used/unused and change their state in Windows XP and in Vista?
Thanks in advance!
Im trying to setup my Nagios system so that when specified services fail it can shut down my Windows 2003 Server. I figure I can do this with a script of some kind, but I have no idea where ...
Does anyone know how to get a count of Windows Terminal Server user accounts using SNMP?
I'm running:
- Windows 2003 Server Enterprise Edition, fully patched.
- Cacti version
Specific...
We have a client with 2 offices. The offices are connected by 2 point to point (non-bonded) T-1.
They don't like the speeds across the T-1, but they don't want to spent the money to increase ...
Need to remove and re-add a xp workstation to the domain using a command prompt. Need to do this to a remote computer and not the local computer.
Hi.
I will move to a pair-house. (My sisters house)
She alreday have internetconnecting and a router (A).
I will have a cable from that router to my part of the building.
There I hav...
I have a Debian Etch box that I'm running at my router with ntop installed. Under the network load portion there are three graphs going back at least a month. When I click the "last month vi...
I seen that my network engineers adding route and gateway to routing table( Both linux and windows)
Why they are doing that. In what circumstance they will do that?
I know routing table is f...
I can not add a password to a new user or change a password using ConsoleOne on my admin workstation. When I try to add the user I get "error 319- An internal program error has occurred" I c...
I have a LAN(192.168.1.0) with CISCO CATALYST 3500 XL switches and Sonicwall 2040 with T1 connection to outside. I'm thinking of adding a wireless network to this layout giving only internet ...
Does one way of printing have an advantage over the other? Either using TCP/IP or one of our servers as a print server?
I have just moved into a apartment. IN my house I used to have my dsl router and I could firewall and protect devices much easier. Now that I am in the apartment I have been patching into a LA...
When the Master DNS is offline, the secondary DNS server doesnt resolve queries.
Ipconfig on my pc shows only the master DNS and no alternative.
Why can't the network see the seconda...
I want to maximise my network speed as some users have complained of poor network performance. I want to start by making sure my servers (x5 HP proliant...) are patched correctly into my swit...
I don't quite understand the following scenerio:
I want to Ping from Server #1 to Server #2 across a point to point T1
Server #1 Router #1 ...
I have two computers on my home (wired) network -- let's call them Server and Desktop. Both are running XP Pro. I can see the shares on Server from Desktop, but I cannot see the shares on De...
On a netstat -a command, there are lots of ports listed, what does a listening port and an active port actuall mean and how does one tell if there may be an intruder trying to hack into your c...
Hi. I'm fairly new to networking. I've been browsing similar questions and have gotten a feel for the general concept of what needs done. However, I feel like I'll need some direct feedback...
ssh into the extreme box:
Keyboard-interactive authentication
Enter password for admin:
This is the error:
channel 0: open failed: resource shortage: Channel open failed
It wor...
Hi there
This is just advice more than anything else, At our school we have new fast internet and have ISA firewall 2004 with surfcontrol, I have stopped U tube to the kids, etc, But they a...
hello
i am looking for opinions on products that will give me a picture into the usage of bandwidth by users/workstations and the application that is using it. note that i'm not looking fo...
Greetings, I'm working with a friend on developing a web app using visual studio and for source control we're using VisualSourceSafe (internet) hosted on a server in chicago where we can check...
I want to monitor file usage on my network (shared files and folders).
I dont know the best way to approach this whether theres some software/tool that can do this or some sort of script.
We are currently looking to block users on our network from being able to install software without the IS departments knowledge. One idea we have come up with is to use a global policy to all...
