The server has been abending at least once a week sometime twice. The running process is different each time. I am wondering if this could be a memory issue.
Server WORKHORSE1 halted Tues...
Looking for the Best Practices way to migrate from an existing production server running Netware 5.1 sp7 and Zenworks 4.01.
To a new server running Netware 6.5 sp5, Edirectory 8.8 and Zenwork...
Hi - all of our printers need to be re-addressed. The NDPS manager/broker server IPs will not be changed, just the printers themselves. Is it any more complicated than modifying the NDPS obj...
I have the Intranetware CD and I want to install a Netware 4.11 server.When I type "Install" at the Cd-ROM prompt I get the initial Language prompt. then the screen goes bkank, a blinking cur...
Short Version:
Applications that are associated to workstations as force run (lights out distributed applications) are suddenly not working consistently. These applications do things like ...
I setup a new Netware 6.5 server - the works - all done. But I failed to install NDPS when I did the install.
Can I add NDPS without starting all over? I think I found a place to do it, but i...
hi experts,
i have a zenworks application object installed in one container. i need to install this application on several containers. i have exported this application using ice and created...
Hello there is a great opp for me at my company to take over the management of IDM I did post something a couple of months ago, but since then I went in to the windows group, this position is ...
Hi
We have a problem there a couple of our users gets the Novell Security Services Login dialog. The users are already logged in to Active Directory and authenticated to NDS through the mi...
I have a workstation that I want it to bypass the Novell login splash screen when rebooted. The only time I want to log into the network is if I manually invoke LOGIN. Reason is because I also...
I need to add at least 200GB of storage to two locations with older servers having no room for additional disks. Was looking into the Adaptec SNAP server with 500GB for under $1k, but no RAID...
I have a need to prevent a certain user account being used on a subset of computers, all connected to the same Netware tree.
I thought about doing this in the user's login script. Each of o...
I have a Netware 6.5 server with a Intel PRO1000 NIC. It is plugged into a Cisco 4560 switch. Most of my clients are in VLAN1 right now and I want to start moving users into different vlans....
I have a Netware 6.5 file server that holds our shared files. What steps do I have to take to migrate all these files and rights from Netware 6.5 to a new OES 2 server. Is there a tool to us...
Running Novell Netware 4.11 now, but symantec backup exec 11d only supports netware 5.1 and up. the backup agent wont work for 4.11.
Is netware 6.5 the best out of all the other versions?
Have a CLIPPER/DBASE APP THAT WAS PRINTING ON A WIN98 BOX TO A NETWARE 5.X Q USING A BATCH FILE WITH A CAPTURE STATEMENT IN IT. MOVED TO NW 6.5 NOW THE PROGRAM WONT' PRINT, Q'S ARE GONE, THE...
I have several users that use Calendar Creator 7.0. They use it and print all the time from it.
Recently I deleted everyones Queue based printer and replaced them with iPrint pritners.
We have 2 brand new laptops(running 2000) with 4.83 client trying to login to 4.11 netware server. All users can log in to the network from the laptop, except one. When this user tries to lo...
I have a user that accidentally deleted his calendar. We do backups every night, but is there a way to retrieve his calendar without restoring his entire userxxx.db file?
I am having issues with Backup exec 11d running on a WIndows 2003 server. I am trying to backup my Netware 6.5 sp6 servers using the Backup Exec remote agent for netware. When my backups run...
I deleted the DNS AG for one of my servers. How do I recreate it?
How do I update the firmware on an IBM Half-High LTO Gen 2 drive. This tape drive is installed in a NetWare server. All of the tools I've found are Windows based.
I have two Xerox printers that I haven't been able to get iPrint working with. An older 8830 and a new 6204. Now, they both work with IP printing using Windows drivers, no problem. I setup ...
I am new to Novell. This morning we had 2 abends. This is the abend.log file. Can someone please help me understand, in newbie terms, how to read this log?
Thank you.
Novell Open Ente...
When i try to connect to my smtp server it requires authentication.
571 Remote sending only allowed with authentication!
That's good, but when I connect trough telnet:
telnet ...
