Time Tested OS/2 Network Security Solutions: 1 - 24 of 24
  • 1
Hi I have Cisco 3600s and I want to block Netbios ports (ns, dgm, ss) over my WAN network (frame-rely)on subinterfaces. I have tried a several rules, but cannot seem to get one works right....
Hi, I am trying to simultaneously dial-up into 2 different Thin Layer servers (Axis Video Server: for remote surveillance) from a one PC. These video servers have got different IP addre...
My OS/2 computer is connected to a LAN, which is connected to the main campus server by a T1 line. I need to connect to a drive on the main server. Others on my LAN can do so in Windows 95 ...
What are the Advantages of OS/2?2-0
Hi The first question is this: Can I run TCP/IP on two NICs and have the same IP adress on both cards? If so...how is this done (detailed instructions please)? (I have tried installing...
Probelm: Can not logon to "domain A" from "domain B" over TCPIP network. Need a step-by-step MPTS setup procedure to get "NETBIOS over TCPIP" to work.
My server can ping other file and application servers.  However, it cannot ping its own IP and router.  I have MPTS and TCP/IP v.3 running on OS/2 Warp Connect 3.0.
I have a new Powerbook, WinXP, Win 98, Win 2000 in our home/small business.  I just added the Netgear PC Wireless Adapter to the Win XP.  Since the introduction of the Powerbook I often lose c...
I have three server in a different subnet not running Wins and the domain name do not show up in network neighborhood.  Do I have to was Wins running for this to occur?  If not what would be t...
otta: I am directing this problem to u cause ur the man this category!    I hope the mods don't jump all over me cause i violated some protocol!!    I run win2000-384 mb of ram-60gb hd-cabl...
How do i have to setup Putty so i can ssh to a server, even if i'm behind a proxy. my only open ports are 80, 443 and 5900. I've moved the ssh deamon on my remote server on 5900 port, but i ...
Hi We are having 7 server of which one is exchange server i have installed spiceworks on this server. Now we have norton antivirus corporate edition where all the scanning is done. Some how...
How do you get an OS/2 DHCP client to show the hostname in the DHCP manager for WindowsNT?  When I pull the info up in DHCP manager, it will only show the MACaddress of the machine.  I need it...
I originally had installed a licensed version of OS/2 Warp 3.  Early last year I updated this to Warp 4. After successfully linking to the internet via TCP/IP I did something (I've been fiddl...
please let me know any good sofware, which i can use for sms purpose from pc to mobile.
Hello... Just wondering, when you run a cat 6 cable let's say from a GIGABIT Switch to another computer... can the cable be longer than 164.04 feet? I have heard that in a Gigabit ethern...
I wanted to know if the emails that I send from my work system can be intercepted and read by someone at my company.  Are there any utlities that allow to do that at the client console, I do n...
I have set the login time  in Active Directory for my network users , for some users, this timing is not working properly. e.g. i have set the timing for user "userA" upto 6'O clock, and for ...
Are SO_RCVTIMEO and SO_SNDTIMEO valid options on setsockopt under OS/2 ? If not, is there anyway to set the timeout values. BSD seems to allow this as well as some winsock implementations. TIA...
Hi, I am running OS/2 version 3 and would like to know how to install a Microsoft client that will enable me to share files with an NT machine.
I have Warp 3 and want to connect to the local network (NT4 server). How can I do this? Is the only way to buy the Connect version or is there any drivers / updates availble for Warp3??! -- J...
Does someone happen to know if it is possible to build a token-ring LAN with Novell Netware 3.12 server and OS/2 Warp 4.0 workstations using IPX ?
What is the difference between the keywords "Pxe DHCP" and "PxeProxy" related to the IBm DHCP Server configuration file.?
I dual boot between OS/2 & Win98.  I have an ADSL account with BellAtlantic.Net.  I'm in 98 now & it works.  However, when I boot into OS/2, I get an error message that says DHCPSTRT did not g...
  • 1
