Hi there,
Ive heard abt this technology CRA/CRS (used in VOIP) and pretty similar in functionality to Cisco Call Manager except that the CRS is used for small scale deployments...You can have...
I'm using Cisco CallManager 4.1
After 5:00pm Eastern, the message that customers would receive when calling in would say that we were closed and would not transfer them to our hunt group...
Here's the issue, as strange of a setup as it might sound. We have a remote home-based user who has an existing VoIP phone utilizing a Cisco ATA186 device. Not sure of the provider just yet. W...
Hopefully this is possible and something really simple. We are running Cisco Call Manager 4.0 and have mostly 7940 phones. On phones with more than one line appearence. How do you choose the n...
I need to spec out a voip gateway, any help would be appreciated
1) Expected approx 20 concurrent connections
2) I want to use a Cisco router
3) what type of network module do I need?
4)...
Dear experts,
I have a network with 4 3560G switches, 2 3750G and 1 ASA 5550.
SW1(3560G) is trunked with SW2. SW2(3560G) is trunked with SW3. SW3(3560G) is trunked with SW4(3560G). SW4 is t...
http://forums.blueface.ie/showthread.php?t=1585
Is there any updated firmware to cure this?
Hello, I recently had to rebuild my Publisher. I have now found that under Applications --> Install Plugins nothing works. How can I reinstall the Plugins section?
It looks like Cisco's IP Communicator is unable to dial digits when installed on Windows 7. Works fine on XP or Vista. Does anyone know of a soft phone that speaks skinny, and is compatible ...
I have a few Cisco 7960 phones. They are six line phones. On one phone in particular, the user acts as support for several other line appearances on the phone. In other words, the first line i...
is it possible and if yes, how to have a way to call free between several countries having just internet access without PSTN?
Please tell me in details what is the equipment needed ...
Hi ,
The 7940 phone that is hooked up on the CME router does not load instead goes in a loop.
configure vlan OK
verify load
downgrade application
copy to bank 1
and then back to...
greetings,
we have cisco phones being used in our organization with cisco unity express and would like to know the following :
how can i delete a number from the existing local directo...
CUCM 7.1
Unity Connection 7.0
I set up SCCP integration between CUCM and Unity Connection and am able to leave voicemails for subscribers. Everything seems to work fine. I get a greeting, ...
I need to figure out how to approach IP Faxing. My users want faxes to go to their email. To accomplish this are all configuration's done on the Cisco Voice Gateway Router? Is there any con...
We have a CallManager Express with 4 BRI ports. We use all ports to make outgoing and incoming calls. Now, we want to configure one of this 4 BRI ports to make speciific outgoing cal...
Hey Experts,
I have a VCX Connect phone system which does not work good with external nat without a VPN tunnel. I am looking for a SIP Proxy which handles this NAT. I tried setting up a OPE...
My Cisco UC520 will not allow me to change the dialing plan (outgoing) so that it sends the 10 digits down, for our PRI provider to route the call, for some reason it is sending 7, or 8 with l...
I need to enroll in Google Voice. I have requested several invites using all 8 of my email addresses, but have yet to have been invited to join. What can I do to enroll in Google Voice ASAP?
Free PC Remote Control Solution
I have very small low budget Tech Support Business.
1. I want to put a download or a link on my website so that I can offer a service where I can remote...
I need to create a trunk between a call manager and a call manager express. I am using the call manager as the gateway and need all calls that are not internal to go that direction.
My numbe...
Does VOIP phones benefit from being on its own VLAN?
Okay, so here is my issue. I have 2 Trixbox PBX systems running on the same network. and i need to be able to register my phone to use both systems. example: if i dial x7000 i use the main sys...
My CME router CLI is filled with messages the ephone 5 registers and then unregisters in a loop.Please advise.
18:23.918: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-5:CUC1-VI1 IP:192.168.0.20 S...
On my network we have a Cisco 1841 router, 2 GS478TP Swithces and 1 Linksys SRW2008P switch. There are Linksys 54G WAPS.
We have a trixbox phone system using Polycom IP560 phones. We are us...
