2000 organizations, including eBay, Ericsson, and Lockheed Martin, now work smarter with Corporate Accounts. Save over 36%!
Time Tested VoIP Solutions: 226 - 250 of 669
i am trying a simple test and banging my head against the wall. basically as a test i am trying to mark all http traffic as dscp ef. i realize the priority is overly high etc but basically i d...
i have a phone in a front lobby that i would like to have dial an extension anytime the handset is picked up.
Call Manager Version 4.1, my calls are taking 15-20 seconds once the last digit is pressed to start the actual "call" - I can see that the call is not being sent to the core voice router from ...
Hello, I am interested in: -connecting 3 houses with few Cisco IP phones in each -the connection between those houses needs to be via the internet -the internet is reached by ADSL/CABLE mo...
hi we just recenlty bought plantronics headsets http://www.plantronics.com/north_america/en_US/products/cat29880043/cat29880048/prod350006 they have a connector at the end of them that ...
I have a adtran 1335. I was wondering if my QoS looks to be setup properly for VOIP. The phones are Polycom with a CoS of 5. The dscp on this phone is 40. We have a T1 for the wan and have SIP...
Hello, I am not sure if anyone out there can help me?!! here is the idea I have: I have a VPN tunnel between 2 sites (say site 1 is NYC and site 2 is CA )  I would like to be able to place...
I am trying to set up trixbox to simply route internal calls, (I don't need to make external calls at this stage) and am failing miserably. Although the phones can communicate using IP address...
I have a setup running running an Avaya IP Office setup, and 4 remote VOIP [5602SW+ IP] telehones. These work fine, however when teh ADSL line that carries the traffic into the main site get b...
Hello, I would like to configure a hunt group in Cisco Call Manager Express so that when someone calls a number it rings on two users phones at the same time allowing either user to pickup ...
I have a new Dell 3548P setupfor voice vlan and a gb uplink from there to a gb link on my 2960 I would like to tag all voice traffic coming to Gi0/2 (the Dell 3548P) and get it properlt pri...
We currently have one flat network.  We are setting up a VLAN. One for voice and one for data. Here are the specs: Core switch is 5308xl Core switch port a1,a2,a3 uplinks to voip switch 1,2...
Hello All - I am in the process of deploying a VOIP system. I will be using an HP 3500 POE switch for the phones as well as the workstations. I am planning to have all 48 ports in the nati...
Dear All I am trying to make libjingle's call.exe work on my own ejabberd xmpp server. I can login and initiate a call but that is about it. Anyone knows about known issues or another se...
Hi, We have been running a 3Com NBX-100 system for some time now with the following configuration: *E1/T1 PRI Card for trunks *MOH *IP On The Fly Recently we brought a remote office...
We are in the process of replacing our PBX system with an Asterisk system. We have a analog phone in the hall by the front door, that we keep locked at all times. In our current PBX we have...
I have a QoS question hopefully you can help.  I have three sites (A, B, and C), each with a 2621xm series router and a catalyst 2950 switch.  Site A and site C are connected to site B via a f...
I have created an POTS/analog autodialer program in VB6 using Dialogic cards which sequentially places multiple telephone calls to various telephone numbers. Obviously, I have long distance ...
Hello everyone, Our organization is currently looking at upgrading our phone systems.  We currently have 7 office sites around our state, which all have old key based phone systems.  One av...
Wow I guess cisco and SIP are a sore subject here no one is answering anything I post. Anyways I have a setup like this comcast --- asterisk box ----- LAN  ---- MY PC ---- Cisco 7971G-GE -...
hi does anybody know a SIP application layer gateway(nat) software the best would be : freeware, for unix like os, but can be linux also.... thanx a lot regards R.
our isp provider block port 5060 (sip port) any solution or any way to bypass isp block thank u
The clock appears set fine in IOS and in the switch service module. (See below).  But the phone's time is off by six hours ahead.  I've rebooted the phone and it's still way off.  To what is i...
I'm running Windows XP Pro, ADSL service with an international (Poland) local phone service via USB modem (Thomson Speedtouch 330).  As I live in Poland and all my family is in the States I wa...
Hi, these two thing always appear on the rate that the terminator gave, i need to know what does ASR/ACD stands for ? regards
