We have bought a 4610 IP Phone to try on our phone system however we are struggling to get it setup. Its detected in IP Office Manager and has an ext assigned. We have updated the software on ...
Can someone help me out in creating a config for the 2811 12.4.20T1 router to use it with a VIC2-2FXO card so i can receive calls from the outside and make calls to the outside?
I ne...
Hi, I am looking for a VOIP SIP OCX to add VOIP capability to an application. At this stage the ones I found seam to be licensed on the per user basis, and quite expensive too.
Is there one...
after login to the extension mobility
,i try to press the services botton again to get the logout option
but i m not getting the logout option i am getting this message as ithis services...
My Cisco expert is telling me that Cisco makes no distinction between incoming calls to it. (In regards to interfaces).
So, if I get 7 digit DNIS (via a PRI), and want to be able to place...
hello
I have a SIP account that I can use with a softphone like x-lite or sjphone.
Within the same network I have a SIEMENS HG1500 PABX.
Can Asterisk be configured with SIEMENS HG150...
Hi there
I'm looking for a cisco router that support h323 can any advice me and give some cisco models that support h323 because i can't find any ..
Hello:
I am evaluationg to buy a line conentrator for POTS that registers each line using the H.248 or MEGACO protocol. I want to connect this using asterisk but I am not sure of the compat...
Hi
i want to attach asterisk with SQL DataBase using AGI. i am interested in using Dot Net platform. can some one guide me on the fact that C# (Dot Net) can be used for this purpose and wh...
I'm currently running Cisco Call manager 2.4 on a HP proliant server. During a exercise everything was running fine. Until I decided to change the IP address on the Call manager. When I added...
Does anyone have a step by step guide or can walk me through the process of setting up extension mobility? I tried following one from Cisco, but I must be doing it wrong because the service w...
My company has IPT in our HQ. We have a secondary mfg location in the next town that is connected via a point-2-point T1, and we run VoIP over it. We have a PRI for PSTN access at the HQ. The ...
I would like to know how to change all "ephone-dn" already created to "ephone-dn dual-line" in Cisco CallManager Express.
Thanks in advance.
Alejandro.
We have just deployed a new VOIP telephone system from Avaya, we are using the internet to route our calls over a 2meg lease line. Voice and data traffic is kept separate on our internal netw...
I have been trying to solve this for months and haven't really gotten far.
I have a SR140 brooktrout ina server running FACSYS, and incoming fax's are working fine.
the main out bound Dia...
I need to know a way to back up our Cisco Call Manager 4.0? I want to back up the database/numbers and settings so that if the CCM goes down I can restore it on to another CCM 4.0 system.
Looking ahead to our future VOIP implementation. I'm wondering just how 'ok' it is to roll it out with a single cable from the POE switch. Cable goes into VOIP phone then another from phone ...
Our problem is we have Cisco Routers with the proper qos running. However our catalyst 3550 does not have the proper qos. Our phone system is a nortel BCM and we have nortel phones. I went ...
how can i implement SIP protocol using JAVA? If not java any other language like C# or C++? but preferable java.
any tutorials, i want to implement a project. Any hardwarre reuqired, i hope...
I have a newly installed Unity 4.0.5 w/ 100 User Unified Messaging License. We are currently using Exchange 2003 as our email server. The Unity Installation went fine, no errors. The Partner S...
I'm currently using a 3Com NBX 25. We have outgrew the system and have even had hardware failures lately. I'm trying to find a decent replacement that isn't too difficult to install and confi...
I operate a BTS10200 Cisco SoftSwitch.....CAT 6509 as the Main Switch, and an AS5400 HPX as the current Voice Gateway. All of my customers are connected via T1s with Cisco IADs (2420) back to...
hi folks,
I have a conference bridge in a secured datacenter which receives VoIP/SIP calls from public internet. we recently changed firewall from an old/simple netscreen to a newer Juniper...
We are having a problem with a pair of Avaya IP office 500 telephone switches - both running version 4.2 (14). They are on two seperate sites which are connected via an IPSEC site to s...
Unity Connection is Turned on in Port group and users the box to to enable is checked but the
status show checked.
How do I solve this issue.
