Time Tested VoIP Solutions: 301 - 325 of 667
Unity Connection is Turned on in Port group and users the box to to enable is checked but the status show checked. How do I solve this issue.
Hello, I have a Cisco 7940 IP Phone and defined an internet URL for the phone to pick up a basic graphic, however I dont think that the phone is picking up the URL correctly and the graphic...
Can I get a "layman's" definition of when to use an FXS card vs. an FXO card?  I'm setting up a small CME install....cisco 2851 router with a 48 port 3560 cisco switch, with 30 7940 cisco phon...
I have a Cisco CME on a 2821 router, it is running CME 4.1, Unity Express 2.3 and IOS 12.4(1)XJ3 I want to upgrade to CME 4.2, UE 3.1.2 Looking for a good document on doing so
I want to configure asterisk as a PBX xchange for the VOIP project i am doing. All i have is a Sound Card, a tel. line and an external modem in red hat 9.0 Is it possible for me to have the ...
Trying to enable igmp snooping on a 3500XL 12.0(5) switch.   when I enter ip igmp snooping, I get invalid input.   When I enter ip igmp ?, I get ambiguous command.  When I enter ip igmp,...
We have had Cisco call manager installer for a few years, it was installed by an external supplier we have a Music on Hold wav file entitled opus_number_2.ULAW.wav I have always assumed that...
Hello everyone! Well after a lot of research and checking on various PBX systems, someone mentioned Elastix and kind of got me hooked on it. Now, we have decided to go the Elastix route ...
I currently have a Call Handler that is configured to ring a hunt pilot, if no one answers it goes to voicemail, and the message is distributed to the staff via public distribution list.  The ...
I have recently gotten asterisk running on my linux server and tested two xlite client connections on my lan, so calls internal to the lan work, but not with my VOIP phone.  The lan is nat'd b...
Hi, One of my client is having VoIP setup in her office. He is asking me "is there any way to to call VoIP IP address from the Skype "  I am not sure about this. could any body khow abou...
I am trying to add additional Call Manager server into cluster. Currently I have single Publisher server with 4.2(3) version of CallManager installed. I bought new licenses and installation C...
We have three offices across the State and are upgrading our phone system in one of them now. We are considering that in the future we could use the VoIP feature to save some money since we co...
Hello everyone, Our organization is currently looking at upgrading our phone systems.  We currently have 7 office sites around our state, which all have old key based phone systems.  One av...
I am working with Cisco CME 3.3 and I recently got Cisco 7960G IP Phones and have the P00308000700.bin file assigned for 7960-7940 IP Phones.  The problem I'm having is the phones boot up, con...
If we put the Inter-Tel 8520 phones on a port with switchport access vlan 2 (the voice vlan), they get the correct IP information from the DHCP server.  If we put the phones on a switchport wi...
Hi, Can someone help me out in creating a config for the 2811 12.4.20T1 router to use it with a VIC2-2FXO card so i can receive calls from the outside and make calls to the outside? I ne...
Hello, is there any ATA that has a VPN client or OpenVPN built in? That way I could connect securely to my PBX from remote locations. Thank you!
ip subnet-zero ip cef ip domain-name ALTER.NET ip name-server  primaryDNS ip name-server  secondary DNS ip name-server  Tertiary DNS voice service pots fax rate voice voice class code...
Using a TE411P 4 port E1 card in the UK. All the ports are TDM primary rate EuroISDN (30B+D). My Asterisk server receives inbound calls on port1 (from the local BT exchange) and sends them ...
hello I have a SIP account that I can use with a softphone like x-lite or sjphone. Within the same network I have a SIEMENS HG1500 PABX. Can Asterisk be configured with SIEMENS HG150...
Hello I have just installed 1 x Grandstream GXP-2000 VOIP Phone (Sipgate Service Provider) with some degree of success (See below for problems). However as this is my first experience with ...
Can someone give me a walk thru for installing and setting up a digium 3 fxo card for 3 analog ph  lines
Hello, I'm trying to put a csv file in my aastra telephones to make the directory have numbers to dial to. I have acces the phones webpage and went to configuration server filled in the h...
I am trying to configure a Win2k3 server as a DHCP server for my Cisco 7945G IP Phones. The phones are in VLAN 20 and the PCs are in VLAN 10. I have two DHCP scopes built on the server. All PC...
