2000 organizations, including eBay, Ericsson, and Lockheed Martin, now work smarter with Corporate Accounts. Save over 36%!
Time Tested VoIP Solutions: 426 - 450 of 653
An end-user of mine has an issue with his new VoIP phone where he can call other people however he has no audio on his end.  I have searched and opened ports, but no luck so far. Here's the...
Hi! I am hoping that someone here has gone through a similar situation before and can help me figure out which would be a better system. Environment:  We have 5 sites connected by an MPLS ...
We are in the process of replacing our PBX system with an Asterisk system. We have a analog phone in the hall by the front door, that we keep locked at all times. In our current PBX we have...
I am running CME on a Cisco 2821 router. I can direct dial into 2 of my Cisco IP phones. I cannot direct dial into the other 24 Cicso IP phones. I cannot see any difference in the configuratio...
I need help in setting up Voicemail on my cisco box. I have created 10 vmail ports, a Line Group, and hunt list.  but when I call the first number in the directory that I set up using the v...
I am a professional salesperson and I have been approached and offered a sales position by both an Avaya dealer and a Cisco dealer in the VoIP industry. Both seem like solid companies but I am...
I am having an issue with one way audio. We are using Secure Remote for a vpn client and when we use IP communicator the audio flow is one direction. If I call an external number the remote pa...
I am running CM 6.1 with 2811 gateways, each with a PRI installed. How do I see how many channels are in use at any given time? Is there a reporting tool that will give me statistics? I tried ...
Hi, We are having a problem with a pair of  Avaya IP office 500 telephone switches - both running version 4.2 (14). They are on two seperate sites which are connected via an IPSEC site to s...
Hi, I need to upgrade the firmware for the Avaya 9630 handset. I have downloaded 9600 Series IP Telephone Software Release 3.1 but how do I upload the software from the computer. What serve...
I am looking to test out Google voice.  Does anyone have an invite they could send me?
Hello All, We have been with an ISP here in Arizona that has been giving us nothing but grief due to down time, circuit issues, and circuit missconfiguration. We have an MPLS network betwee...
I am getting mixed answers from Toshiba on a IP phone system.  We need to implement QOS on the LAN side (not over a WAM) at a campus.  This campus has a GB fiber backbone across a Xyxel switch...
Hi I am having problems with new VOIP phones dropping out with calls made through the Polycom 430 handsets. If I plug the phone on the switch using a dedicated port it seems to be fine but ...
Hi Guys, I have a cisco unity server. It has recently stopped working in the way it should - users can't access voice mail, and nothing seems to be working correctly etc. I am getting the b...
Hi All I have the following setup Openser Server A --> Uses Localhost MySQL Server Openser Server B --> Uses ServerA MySQL server Each server is in a different location.  Both serve...
I have few Cisco 7960G phones that I'm planning to connect to Asterisk. The phones come with Skinny pre-installed. I need to flash them to SIP. I'm primarily following this manual: http://www....
Dear Experts, I have been going back and forth with different techs both with NEC and Cisco on the correct IOS to use for VOIP.  I have Cisco's 2620 and several 2611's.  They have 64 and 16...
I need to create some custom rings for a Cisco VOIP system - the requirements are the audio files be in .RAW format.  Does anyone know what software is out there to convert/compress audio file...
Dear all, I am looking for a VOIP "solution" (sorry for jibberish) that can plug into an ethernet port have the user lift the handset and be making calls. Is there hardware that, through so...
I have been trying to solve this for months and haven't really gotten far. I have a SR140 brooktrout ina  server running FACSYS, and incoming fax's are working fine. the main out bound Dia...
My customer has a Cisco 2811 switch/router for ip telephony They want me to change the names associated with some of the handsets and some other housekeeping. (employees have left and been re...
We are installing New Avaya  8510 & G450 and Voip Phones In Site A and B (instead of 3com Nbx 3000 which will be moved to Site C ) Avaya Requested Vlan to be implemented on our netwrok (So we ...
I want to route inbound calls via FXO ports on a Cisco Call Manager router out to a sip trunk.  The CUE limitations require me to offload AA and Voicemail to a 3rd party system, and using call...
Hello, I am not sure if anyone out there can help me?!! here is the idea I have: I have a VPN tunnel between 2 sites (say site 1 is NYC and site 2 is CA )  I would like to be able to place...
