Hi All,
I really need your help on how to configure my cisco 3560 router from scratch to have two vlans, once for voice and the other for data.
My Network;
1 windows dhcp server
1 f...
Its so annoying when in the middle of something or remoting a machine and its saying it.
A way to stop it til I wantto restart?
I currently have CME/CUE configured on a Cisco 2811 Router. We are decommissioning our exchange server and going to a hosted Exchange for email. Will CUE work with hosted exchange? I still ...
Does anyone have any experience or knowledge on implementing this type of setup. I need documentation and links for some of this information. We may implement at our office, but I would like...
I will soon be doing a job that will have a VoIP network as well as a regular data network.
My certifier does not have any pre-setup cable tests for VoIP, but I can create custom requiremen...
I have (3) Vonage lines, two on one RTP300 and another on a second RTP300 each behind a single router with a DHCP server . I have both RTP 300's connected by their WAN ports to the LAN ports...
Hello
I am looking a hardware device like dialogic card (but no expensive card) OR software which will accept incoming calls from PSTN or PBX System and call divert to IVRs Java Application...
Hi there,
Need to find open source code for Softphone and configure it for own use.
Can anyone suggest any site or any good softphone?
I am not from networking background, so, will ap...
All,
Could do with some help. I'm trying to setup QoS on my Vigor 2800G ADSL router to prioritize Skypein and Skypeout traffic. I've set Skype to use port 41726 for incoming connections and...
I need help with my asterisk configuration.
I cant find a decent configuration, to use my voipbuster service ( i can use they software very well)
i need a basic sip.conf, or iax.conf an...
I am going to bring up a new Exchange server that will hold the mailboxes that unity uses (unity messagestore, unity messaging, unity message system & unityadmin account).
The last time th...
Hi
I am a MCSE and CCNA qualified guy working as systems administratoar (Managing all microsoft servers). I have done my CCNA recently and would like to switch to a career in VOIP. I am p...
Greeting Asterisk Gurus,
I've had my asterisk box setup and working quite well for the pass 2 months now.
So, for the next step, i would like to experiment with how to connect to my as...
I'm in the computer business supporting small businesses. I have never used, installed, or maintained any kind of VOIP system. I'm familiar with the basic concepts but I do have several questi...
I've set up a call manager express (ver 3.3) and a trixbox (ver 2.2). I can call to the phones on the trixbox from the call manager by using a dial-peer but I have no idea how to call th...
dear all,
i want to build Voip application for desktop using java with asterisk server , but after long search i found
better to use jain-sip ,but i do not know how to use with my asterisk ...
When our users login to the CCMUser page they are unable to Add/Update Speed Dials. I've tracked this down to their phones not being associated with them. However, when I try to associate th...
I have a Polycom VSX8000 unit attached to my Cisco 4506 Switch. I want to have the VSX8000 communicate on VLAN 2 (which is my voice vlan) and I put the following configs onto its switchport:
I have the Avaya 412 with the voip card. I have only the phone manager, configured for voip and it works with in my LAN. My problem is it will not work over the vpn, the vpn is fine ...
I am running CME on a Cisco 2821 router. I can direct dial into 2 of my Cisco IP phones. I cannot direct dial into the other 24 Cicso IP phones. I cannot see any difference in the configuratio...
Hi, I have a callshop that I would like to run using voip instead of the PSTN connection. I bought an 4-fxs ports welltech gateway on which 4 analogue phones are connected on one side and the ...
I am currently testing VLAN's on two 2960's in a lab environment.Do i need to have a layer three switch to get my VLAN's going and routing. I want to seprate the voice from data . Will...
I recently installed a Netgear RangeMax Wireless Router WPN824, v3 in my office building. It's connected to Comcast Modem/Router on one end and wired to EN switch on the other, and wireless i...
I am a very small computer business with only a few employees. I'm looking for a low cost VOIP Solution with the following considerations in order of importance:
1. Software based, running ...
can someone tell me what is better avaya phone system or altigen? please explain
