Visit Experts Exchange from your mobile device to search, ask, and monitor your questions. Never lose touch again.
Preview From Your Desktop
Time Tested VoIP Solutions: 26 - 50 of 669
Both my daughter and I installed Skye on our notebooks. We are able to call one another but the call drops within 1 minute. I think the problem is at her end as I keep seeing the Skpe window p...
Hi there, I am using Cisco Call Manager 4.1 and since we change the hour last week-end (North America) my ip phones did not follow..  When I log on my Call Manager and Unity servers, they a...
couple of month back we implemented CUE and CCME and last week we changed the flash memory on cisco 3825 from 64MB to 256 MB. Actually our support person(voice) copied entire thing and all a...
We have about 20-30 Cisco 7940 series IP phones and 2-4 Cisco 7960 series IP phones in use at this time. At random the phones will reset, sometimes mid call and other times not. All of the pho...
I want to setup a VOIP server on my home CentOS or really any Linux box. Can I do this for free? I obviously don't expect much reliability, mostly for experimental purposes or to take the plac...
I'm having a bizarre phone registration issue that TAC is not able to understand , and i'm hoping someone may have ran into the same issue. I have a Call Manager 7.0.1 server in location A,...
Hello !! I had some noise in the VoIP sound, because there is some data which is uploading from our WAN link at the same time users are tolking on the IP Phone. So I decided to configu...
Hi I'm using a voip service called VOIPBUSTER, but I'm interested in using it with a generic SoftPhone from XTEN called X-LITE. I've configured a VOIPBUSTER SIP account on X-LITE and i...
I'm working on an Asterisk system and I'm finding that the maximum number of incoming calls on any channel is 6.  I need this channel to communicate with a conferencing system with over 20 sim...
I am configuring Cisco 3560 access port to support Nortel IP Phone.. I need seperate VLAN for voice and Data. Phone connected to switch and PC to phone. PC need DHCP lease IP I will set sta...
Hi, I am in the process of migrating my company's CallManager 4.2(1) servers to new CallManager 7.0 servers. However, after reviewing and trying to use the DMA tool to perform the migration...
We have 6 trunks coming into our company.   Our problem is that we are getting too many busy signals when outside calls try to get in. We have 80 DID's and about 80 users. If we got a PRI...
We are trying to prepare our flat network for a Mitel 5000 VoIP installation by implementing VLANs and QoS on our Cisco Catalyst 3560 switches.  I was unable to find any publicly available doc...
Considering the "diagram" in the code snippet: Is it possible to throttle the bandwidth on the SonicWALL (to say 1Mb?) and thus leave 500Kb always available to the VoIP network?
I have a user that has started using the Cisco IP Communicator v 2.0.1.1.  He is looking for a Bluetooth headset to connect to his PC that is compatible with it.  He has tried a USB corded hea...
We have recently added some new Avaya phone systems to our network and are utilizing VOIP to connect our remote sites to our main site.  I have worked with the phone vendor in configuring the ...
I have the following problem with Asterisk after someone installed fax support on my Asterisk server: When I call internally everything works fine. This is how my setup is like: SIP softwa...
Hi, I am trying to configure my Cisco 2811 with Call Manager Express 4.3 to allow generic SIP phone registeration (as well as the standard Cisco SCCP phones). I have used the following reso...
I know this isn't a VOIP question, but this is the only form that I could find that deals with telephones. Anyway, how do I check the phone number extension of a norstar phone?  I can check...
I am trying to get an 1140e phone to request an address other then the default vlan from a Windows 2003 DHCP server. I have setup option 191 for the Vlan info as well as 128 for the phone swit...
Could anybody post an example of simple VoIP configuration on CISCO 2801 router. I have to configure it so it could handle trafic for 10 phones on simple network. phones don't have to go on pu...
I have a pix firewall and an asterisk computer behind it.  I have 2 grandstream telephones outside of the pix and behind linksys firewalls.  We can dial each other, but we can not hear each ot...
I am running Cisco Unified Call Manager 6.1 and everything is working great;  I have about 70 Cisco 7941 and 7961 Phones deployed. I need to know how to register a non cisco phone running S...
Admin account, Advanced View "Line" window, "Dial Plan" section Enable IP Dialing [yes/no] Is it possible to dial another adapter without SIP server? Or, I can dial any user of any SIP ser...
Is there a way to take off the 100 record limit in CallManager CDR Analysis and Reporting?
