Time Tested VoIP Solutions: 501 - 525 of 669
Cisco 2600 Router Cisco 3560 G 24 port Gig Switches Cisco 186 ATA VOIP  (Analog to IP addapter) Hello: I am on a ship with 50 people on board that spend about 8 months of the year at ...
On my network we have a Cisco 1841 router, 2 GS478TP Swithces and 1 Linksys SRW2008P switch. There are Linksys 54G WAPS. We have a trixbox phone system using Polycom IP560 phones. We are us...
Does VOIP phones benefit from being on its own VLAN?
I need to create a trunk between a call manager and a call manager express.  I am using the call manager as the gateway and need all calls that are not internal to go that direction. My numbe...
Free PC Remote Control Solution I have very small low budget Tech Support Business. 1.  I want to put a download or a link on my website so that I can offer a service where I can remote...
I need to enroll in Google Voice. I have requested several invites using all 8 of my email addresses, but have yet to have been invited to join. What can I do to enroll in Google Voice ASAP? ...
My Cisco UC520 will not allow me to change the dialing plan (outgoing) so that it sends the 10 digits down, for our PRI provider to route the call, for some reason it is sending 7, or 8 with l...
Hey Experts, I have a VCX Connect phone system which does not work good with external nat without a VPN tunnel.  I am looking for a SIP Proxy which handles this NAT.  I tried setting up a OPE...
Hello, We have a CallManager Express with 4 BRI ports. We use all ports to make outgoing and incoming calls. Now, we want to configure one of this 4 BRI ports to make speciific outgoing cal...
I need to figure out how to approach IP Faxing.  My users want faxes to go to their email.  To accomplish this are all configuration's done on the Cisco Voice Gateway Router?  Is there any con...
CUCM 7.1 Unity Connection 7.0 I set up SCCP integration between CUCM and Unity Connection and am able to leave voicemails for subscribers. Everything seems to work fine. I get a greeting, ...
We're about to implement some new switches into an existing network and on top of that we have to create a new vlan for some cisco voip phones that will eventually be put onto the lan.  The sw...
Hi, Ok so I have a Cisco 7960 with Firmware version P003Q301 loaded. I want to put the latest version 7.x sip firmware on it but I am having real problems. I have the phone statically conf...
I'm currently deploying my asterisk server on my main network.  My concern is, I'm setting up the Asterisk server on a vlan.  However, i need the asterisk server to be able to connect to the m...
Hello, I have a Motorola FX1900xg (Fixed-static GSM phone), How Can I connect it to an analog FXO or FXS, either one is good, I just need to figure out what VoIP gateway to buy to reduce my...
Hello, On the gateway T-1 PRI under Product Specific Configuration the settings for Input Gain (-6..14 db)* and Output Attenuation (-6..14 db)* I have several users complaining of echo and...
New to CCM. I need to get speed dial set up ASAP for a VIP. We are using Cisco 7941G IP Phones, so I need to get the softkeys configured. Is there a step by step guide somewhere?
Hi Is there anyone know about a free opensource predictive dialer for asterisk pbx............. regards atif
Hello all. We are moving into a new office soon and we will be getting our own T1 circuit and VoIP provided by the ISP (Speakeasy). They are providing the T1 router (Netopia) and VoIP Ga...
I have been looking at the Asterisk Manager API, because i thought this would offer me the ability to connect to my Asterisk machine and edit the dial plan using some of the API commands/actio...
I have the Avaya Softphone client installed on my laptop and when connected via a "hard" connection (RG45 cable), I can connect just fine.  But when I switch to wireless on the same laptop, an...
Hello: I have been battling for a week now trying to install zaptel for a TE410P Digium card. I am using CENTOS 4.4, ZAPTEL 1.4.6  Kernel 2.6.9-55EL . I have no errors in the zaptel install...
I have two cisco routers:  Main office (Call Manager)-->pix vpn-----vpn 871<---cisco 7940 phone. VPN is working and phone at remote site is registering with Call Manager.  Phone can make ca...
I have terrible static when I pick up my phone to the point where I cannot hear anything. Then - and only sometimes - the static settles down the line clears. The image maybe like the packets ...
We have had several 911 calls made from our company today. I open Cisco CallManager to look at call history, but it only shows the last 23 calls. Is there a way to look at all calls made today...
