Hi All,
I have 4 Cisco 7960 IP Phone and CME 4.1 on a 2811.
I am trying to get the 7960 to work with CME but I can't seem to get this working for 3 of the 4 phones.
The error the pho...
is this possible .. i just need information of a phonenumber is active or not .. it should not ring!
i dont think all sip providers allow this ... anyone knows a provider that allows?
an...
Hi All,
Im desperately looking for a solution in which I can have a US Number that will allow me to send and receive SMS and use it in the UK. I checked most of the US Cellular operators and ...
I'm going to list some of the Cisco equipment I have....I need someone to tell me what else I need to get a VOIP lab going.
A few 2600 series routers.
A couple Cat 2950 switches
a 1760 r...
Asterisk takes long time to process dial out calls. After some time it returns saying that number not valid or please check the number and dial again. But same number from my cell phone it wor...
This has been a long running problem. We use the 3COM NBX v3000. We also use the Desktop Call Assistant (actually, because of this problem with the TSP, I've written my own version of the Call...
We have Polycom 501 and 601 phones as well as cisco 7940 phones connected to cisco 3560 switches. We have VLAN 1 for data and VLAN 20 for voice. Last November we added VLAN 50 for data traffic...
Hi Experts
am having LINKSYS phone adapter router. in my office we are having broadband connection with static IP address. the static IP assigned to eth1 and private IP (192.168.1.1) assign...
Hello Experts
I am new with Cisco VOIP systems and was wondering if there was anyone who nows how to setup the Auto attendant to answer incoming calls.
After 6 months, we've finally finished setting up our Juniper SSG firewall. VPN and routes, etc are finally working. All except one thing: VOIP.
I have a VOIP server running on asterisk. I ...
Trying to setup a Cisco Softphone and cannot connect to the Callmanager over the VPN connection. I am able to use all other network resources fine. The softphone works fine while connected l...
How can we convert rtp g729 to wave files or any other format? (Without using asterisk)
Cheers!
i TRIED CONFIGURING LINKSYS PAP2 WITH DLINK ROUTER.I ENABLED PORT FORWARDING BUT STILL I AM NOT ABLE TO GET THE IP ADDRESS USING INTERACTIVE VOICE RESPONSE.PLEASE HELP.
I was wondering if anyone has a config or good instructions for setting a 7971G-GE up with an Asterisk server
I'm running Call Manager 6.1.2 on a new server (replaced 12 months ago). We didn't replace the Voice Gateway (Router) at that time. Recently I had a service tech from the installing company te...
I have a Cisco phone system for a client using a UC520 system. It has 4 pots coming in on the 4 fxo ports. He has an answering service he would like to be able to forward to when he leaves the...
I have no landbased phone, I only want to use Plantronics CS60-USB Wireless headset with my laptop.
Is that possible, or must I have a landbased phone line?
Furthermore, I want to use i...
Hi Experts,
My call center agents will be 5 to 10 and there should be call waiting and forwarding facilities as well.
Please recommend me good service provider in Australia.
Thanks a ...
This seems like it should be easy, but I can't find a solution.
We are using Cisco Call Manager 6. We setup a new LDAP directory (System -> LDAP -> LDAP Directory) for the directory on the ...
Hi Experts,
We currently run Cisco Call Manager 4.2 at our site and we need to add another site in Europe which will have calls routed through our site in order to make calls. We have separ...
I have a new cisco3825=ccme/k9 and would like help getting started.
I have connect through the http://10.10.10.1 address and configured the interface 0/1 with DHCP etc.
I am now trying to s...
I have a stand alone Cisco 2811 with PVDM2-64 (no CCM in our network). My questions are list as follow:
1. Can I use this Cisco 2811 as a SIP call relay to relay the calls between those two...
I am trying to get Call Manager Express to take an incoming call from my MagicJack and send the call to one of my IP Phones. Currently when I place an incoming call I get a dial tone and if I...
I recently figured out how to route incoming calls to an IP phone from an FXO port using the connection plar opx xxxx command. Since I got that working I wanted to see what would happen if an...
Experts,
We need to change our Company's existing AA script from (welcome to ABC if you know the extension number of your party please dial it now (extension starts from 101 to 199) or HOLD f...
