do you know which one is the best IP Phone system.
15 extension and 4 co lines required.
thank you.
I have a bunch of 7960 sip phones connected to a asterisk with regular lines connected via FXO modules to my phone company. Now people using the sip phones can hear themselfs while they`re tal...
I have an Ethernet cable from a PC connected to a Cisco phone, and the Cisco phone is connected to a Catalyst 6500 series switch. CDP is enabled on the phone. Trunking and two VLAN is configur...
I am just installed a voip system using an avaya ip office 401 compact office system. For the remote users, i have downloaded the user software 2.1. Pls tell me if there is a later software av...
We are using a ShoreTel phone system. We're told we can tag our voice traffic going over the wan link by either of two methods: DiffServ/TOS or UDP 5004. The recommended DiffServ value is 'E...
What is a good rule of thumb to use when estimating how many external lines a client would need for their phonesystem? I know this depends on how they all are using the system for ..etc but i...
I would like to know if there is any software that can be used to make calls online. We were using Skype, but the problem with Skype is that you cannot buy a lot of credits. Could you suggest ...
Hi all, i install a asterisk@home. im really newbie in this matter about asterisk. but i need your help please.
scenario.
PBX Siemens Hipath 3500
Box with a te110P (e1)
i install all a...
I need to create some custom rings for a Cisco VOIP system - the requirements are the audio files be in .RAW format. Does anyone know what software is out there to convert/compress audio file...
Is there a basic formula for required bandwidth vs. number of PCs/VOIP Lines? Specifically, would a T1 be sufficient for supplying data and voice services to a branch office with say 5 comput...
I have a PerfectTone IP300 phone connected to my Windows 2003 Small Business Server network using the 192.168.0.x network range. The server does not block any ports.
The server acts as a ro...
I am completely new to the IP phone world and (in trying to save a buck) may have created a hassle for myself. I am trying to connect the 7960 to Broadvoice service on my own, but the phone d...
Hi there,
I really hope someone can help me. I have a Siemens HiPath system with an HG1500 ip card installed in the main office. The route to the outside world is controlled by a Cisco 1800...
I manage a global network and since Skype's introduction have had numerous accounts of end users signing up for this service to save money on long distance calling. Currently, those in the b...
First let me say I was ecstatic to learn that there was a VoIP forum on EE. I nearly yelled out loud. With that I have been reading a good deal on VoIP. I have been exposed to VoIP for a while...
When an agent logs into a queue using AgentCallBackLogin, he should be ready to take calls until he logs out right? For some reason the first time a customer calls the queue, it rings the age...
I have a project coming up where i have to take down our current domain (2003 AD) and move it to an existing domain (also 2003 AD) for our parent company. The big problem is our unity server a...
If we get an incoming call I can edit the callerID provided to add the leading '90' and set the name so that sales calls can be identified according to the number called.
If however the cal...
Hi all.
It seems I have non-stop logging of the following messages about every 60-seconds or so:
Apr 10 06:07:49 DEBUG[1396]: Setting NAT on RTP to 0
Apr...
Hi all..
Im once again attempting to make a messy feature in Asterisk actually useful. Ive managed to correctly tag inbound .wav files to appear as something meaningful: 5551212-20060...
Installing a new 7941 phone & it dials out just fine but when I call it it does not ring or indicate on the display that a call is coming in....
Using Callmanager 4.1
Need answer ASAP
I inherited a Cisco 2811 VOIP system when we closed an office. I don't know much about it. I am able to log into it through the console port. Is there a graphical web interface that allows you...
We are a partnering with a carrier to ready networks for implementing VoIP. I understand the carrier implements QoS on their Router at the demarcation point at client site. That is where they ...
Hi
Can anyone tell me that "how to configure FoIP in asterisk"..............plzz give me the complete answer with settings..
how i can configure cisco ip softphone ?
