If we get an incoming call I can edit the callerID provided to add the leading '90' and set the name so that sales calls can be identified according to the number called.
If however the cal...
Hi all.
It seems I have non-stop logging of the following messages about every 60-seconds or so:
Apr 10 06:07:49 DEBUG[1396]: Setting NAT on RTP to 0
Apr...
Hi all..
Im once again attempting to make a messy feature in Asterisk actually useful. Ive managed to correctly tag inbound .wav files to appear as something meaningful: 5551212-20060...
Installing a new 7941 phone & it dials out just fine but when I call it it does not ring or indicate on the display that a call is coming in....
Using Callmanager 4.1
Need answer ASAP
I inherited a Cisco 2811 VOIP system when we closed an office. I don't know much about it. I am able to log into it through the console port. Is there a graphical web interface that allows you...
Hi
I am a MCSE and CCNA qualified guy working as systems administratoar (Managing all microsoft servers). I have done my CCNA recently and would like to switch to a career in VOIP. I am p...
We are a partnering with a carrier to ready networks for implementing VoIP. I understand the carrier implements QoS on their Router at the demarcation point at client site. That is where they ...
Hi
Can anyone tell me that "how to configure FoIP in asterisk"..............plzz give me the complete answer with settings..
Greeting Asterisk Gurus,
I've had my asterisk box setup and working quite well for the pass 2 months now.
So, for the next step, i would like to experiment with how to connect to my as...
Looking to update our 10 year old DOS based voicemail system to something more easy to manage/update.
Our current system is a Pentium 3 450 PC with an 8gig hard drive 64meg of memory and 2 4p...
Has anyone gotten inbound SIP calling to work with a Sonciwall tz170?
I have a sonicwall with a static ip (1, for everything).. The phones, including the trixbox server, are behind the soni...
Hi! I have CCME 3.3 running on Cisco 2821 router.I have a mix of 7912 and 7940 series IP Phones.
Today all of a sudden my 7940 phones rebooted and is stuck on "Configuring IP".I cold reset th...
Hi all..
i have an old pc, and want to make it my PBX. so, i will use Asterisk. But, i got confused, and don't know what i choose:
1. TriBox.
2. AsteriskNow.
3 install Linux then insta...
I am running data and voip on same physical network. My asterisk server is sitting behind firewall and using Voicepulse as VOIP provider for incoming and outgoing call.
15 workstatio...
I am currently trying to get my asterisk box to work properly with my Tenor AS200 (using SIP). Currently I can call the phones on the Tenor AS200 but I cannot call from the AS200 to any...
I need to setup a CISCO VOIP Telephony solution for a client. (5 extensions)
They specifically requested a system based on 2821 with Call Manager Express.
They will send a technician to conf...
We have a remote site which is about 20 miles away. We need VOIP on the remote site linked to our PABX at the main site, we do not need to connect our main IP network. Can anyone recommend wha...
Does Cisco call manger 4.1.(3) sr4d have a trunk monitoring tool? We are using Unity 4.0.(5). We are having issues when after hours autoatendant is called and a user presses 2 for tech suppo...
We are currently running a Cisco Call manager VOIP solution side by side with a siemens telephony system.
I have a route configured so that a user can hit *3 on a VOIP phone to be able to ...
Does anyone have experiencing with Cisco VOIP - Contact Center Recording . The company
I worked for recently obtained a quote for software package that will run on a stand alone server and
We're having some issues with VoIP quality at many sites. We've tried ajusting out configurations but and it seems to have helped a little but we're still having quality issues (the remote sit...
What is cuasing the following Error and how do i fix it?
I have a Mitel 3300 IP phone controller and a NuPoint VoIP voicemail server sitting on my server subnet. I can place an IP phone on my DHCP subnet and cannot pass DTMF across to the voicemail ...
I must create a network to network VPN for my coworkers. The VPN will be used (primarily) for IP phones. My ideal situation would be to create a Linux-based VPN server, and find a hardware dev...
Here is my question:
I have two sites that are joined via a fiberlink connection between two switches. How do I configure the network to support a phone in site A that will be supported by...
