Hi
I have a Zultys MX 250 IP PBX running on software version 2.0.10. And I also have Cisco IP phone 7940 and 7905 that is SIP aware.
I am able to get the phone to point to the MX 250 ...
i currently have three locations in which operations run out of. In the newest location we have just finished deploying a cisco voip system. Call manager is located in this building. The ot...
hello,
im having problems cancelling audio feedback in a voip application:
does anybody know of any sources or snippets in 'C' for algoritms
to handle this situation... the voip applica...
Does anyone know if the DLink DVG-1120m is able to be configured/administered from a remote location like many routers? I'm trying to help my mom configure her's to allow Remote Desktop Connec...
When I try to run reports in CDR Analysis and Reporting I get an error code 30061 for all reports I try to run. The services are running but ever since I ran a purge of the database I get thi...
We have installed a Cisco VOIP system to replace out old PBX. Overall we are very happy, but we have a nagging problem.
We interfaced our old analog phones. modem lines, and faxes to the n...
Can Anyone recommend a good billing system for prepaid phone services...where a call comes in and is routed to a line that pays for the account...
And will terminate them if their account is ...
I just bought one to use for my VOIP system. I need to find someone that can assist me with configuring this gateway.
do you know which one is the best IP Phone system.
15 extension and 4 co lines required.
thank you.
I have a bunch of 7960 sip phones connected to a asterisk with regular lines connected via FXO modules to my phone company. Now people using the sip phones can hear themselfs while they`re tal...
I have an Ethernet cable from a PC connected to a Cisco phone, and the Cisco phone is connected to a Catalyst 6500 series switch. CDP is enabled on the phone. Trunking and two VLAN is configur...
We are using a ShoreTel phone system. We're told we can tag our voice traffic going over the wan link by either of two methods: DiffServ/TOS or UDP 5004. The recommended DiffServ value is 'E...
What is a good rule of thumb to use when estimating how many external lines a client would need for their phonesystem? I know this depends on how they all are using the system for ..etc but i...
I would like to know if there is any software that can be used to make calls online. We were using Skype, but the problem with Skype is that you cannot buy a lot of credits. Could you suggest ...
Hi all, i install a asterisk@home. im really newbie in this matter about asterisk. but i need your help please.
scenario.
PBX Siemens Hipath 3500
Box with a te110P (e1)
i install all a...
I need to create some custom rings for a Cisco VOIP system - the requirements are the audio files be in .RAW format. Does anyone know what software is out there to convert/compress audio file...
Is there a basic formula for required bandwidth vs. number of PCs/VOIP Lines? Specifically, would a T1 be sufficient for supplying data and voice services to a branch office with say 5 comput...
I am completely new to the IP phone world and (in trying to save a buck) may have created a hassle for myself. I am trying to connect the 7960 to Broadvoice service on my own, but the phone d...
Hi there,
I really hope someone can help me. I have a Siemens HiPath system with an HG1500 ip card installed in the main office. The route to the outside world is controlled by a Cisco 1800...
