Visit Experts Exchange from your mobile device to search, ask, and monitor your questions. Never lose touch again.
Preview From Your Desktop
Time Tested VoIP Solutions: 76 - 100 of 657
Ok heres hoping one of you Asterisk Guru's has had this issue and fixed it successfully. I am running Asterisk 1.2.24 and am having problems during calls to Playback() or Background() durin...
Perhaps the nature of this question is not IT-specific enough for Experts-Exchange, but I'm going to throw it out there anyway... We are attempting to implement VoIP between two branch offi...
Hello, here is the problem i have been presented with. A client has (2) office connected via an MCI world com MPLS connection (full t) Routers are a Cisco 3600 at one and and a Cisco 2...
Hello, I am trying to install dahdi-linux-2.1.0.4 on CentOS 5. I am following the direction in the document: http://www.cahilig.org/installing-dahdi-centos. I get the following error whe...
Cisco Call manager: Need to know how to set up speed dial numbers on a Cisco IP Phone model 7960. Does anyone have a solution to doing this? Thank you, DSterling
Does anyone have experience with Avaya IP Softphone 6 on Vista? I have version 6 SP 4 installed on my XP machine, and it works fine. I installed it on my Vista machine, and it will not connect...
Just set up a new 2811 with an e1. I can dial out from the router, however it wont take calls. Here is the q931 err i am getting can you help??: Nov  6 04:30:18.355: ISDN Se0/0/0:15 Q931: R...
Having some issues with the NAT/Firewall settings in the SIPmacaddress.cnf configuration files for Cisco 7960 phones. The inside phone next to the Box can register and work with our Trixbox ...
Hello, I'm trying to set up LLQ for VoIP on our new T1 to XO. The T1 is NOT installed yet, so I don't know if that makes a difference or not with the error I'm getting. I just uploaded a ne...
how can i fix the time settings on our cisco voip phones to reflect the daylight savings? Thanks
I have recently been thrust into the position of supporting my company's network and VOIP phone system.  We use a Cisco Unified 500 switch running several Cisco 7971 IP Phones.  Management is ...
I recently started working remotely and decided to go the VoIP route to make my being physically out of the office a bit more transparent. I'm no expert on the matter and I'm sure their are si...
I am doing VoIP using Asterisk PBX, and using a softphone on my PC. Asterisk states that ports 5060 and 10000-20000 are needed for the phone system. So in my Buffalo router running Tomato firm...
Hello every body my cisco call manager express is trunked with an asterisk server, i want to route the outbound call coming from the asterisk server (called number with the 00216 prefix) vi...
Hi all; kind of new to the VoIP scene, so please bear with me. I just purchased a Cisco 2851XM router and have successfully configured CME and about four 7970 phones to call each other int...
Experts, We are running CCM 6.0.1 and the majority of the phones in our office are 7960. We just added some 7962 phones and I'm trying to setup the busy lamp field to see when a particular ...
we use cisco ip phones at work and i like it a lot. Is there any way i can setup cisco ip phone at home too?  I am a complete newbie to this, if it is possible what do i need to to get it work...
Hi experts, i need to setup from zero QoS for our voip & wireless SIP phones. In short, we tryed to place out PBX and all ip phone on a separate vlan, but unfortunately, due different version...
Hi guys, I've successfully installed a CCM cluster for 1400 IP phones for 4 locations. However, I have an issue what I cannot solve. The end user would like to change their personal setti...
I am trying to change the display names on phone screen and the users' caller ID but I can't seem to get it to work no matter what settings I change in CallManager, please help.
Hello, I need to know how I can connect to a shoregear switch.  I tried telnet but we forgot the password. I don't know if I can connect using a web browser. according to Shoretel i can conn...
What would cause me to have drops in my policy? If I need to post full configs I can. I have 2 Cisco 1721s connected via t1s to the internet.  I have Samsung ip phones. After a day of use I...
Hi, How i can assign speed dial to buttons in Cisco IP phone 7961 & 7970 from the Phone itself. I have CCME 3845 and now i i found that i can assign the speed dial only from browser. Thats ...
I have the BRI conneted to a BT ISDN service and am unable to make or receive calls to the PSTN. The ISDN connection shows as level 3 up and the gateway is talking to the Call Manager fine. ...
Hi there I'm looking for a Cisco Call Manager Billing software to biil my clients.   also can i add minute to a user e.g 500 minutes to one member after 500 min is finish i want to term...
