We are at the end of the road here and I'm using this site as a last resort. We had a site complaining that they would receive static on the line when making calls external to the network. T...
We have a network of 3 sites all running 2 Cisco 877 (12.4(9)T4) routers with a broadband line connected to each.
We are using Splicecom Maximiser phone systems on each site and I would lik...
I've seen Cordless VoIP handsets used in 24 at CTU but do they really exist? Make/Model numbers please.
When connecting to an asterisk box using sipdroid on an android based phone, you can make calls but not receive. The phone gets UNREACHABLE after just seconds.
If you use pbxes.org then you...
My company wish to integrate to the Vering call recording system. This is a request for information from anyone who may have performed a similar task.
Any information will be helpful.
We have 3 different brands/models of sip and iaxy adaptors. The D-Link DVG-2001S sip adaptor appears to have call waiting enabled, but doesn't have any user config setting to disable it. Thi...
I just need a simple way to record ShoreTel VoIP phone calls.
I found this product: http://www.telrex.com/callrex_how.htm
All that it does is sniff the packets on the network, decipher t...
Hello everyone,
Recently, perhaps within the last 30 days, I've been having problems with using Skype with my USB7100 phone.
In a predictable manner, I am only able to make one successfu...
When I type show channels there are 0 channels in use yet sip show channels returns the records below. Kindly explain. How do I clear them without a restart of Asterisk? Are they a problem?
I am relatively new to Cisco phones and unfortunately came across a problem with the one I have been using happily for some time.
Following the post below I have been looking int...
I have a problem with Cisco Unity Express Version 4.1 with MWI when I recieve voice mail for all my users the MWI stays red on the phone and does not go off.
Below is run configure
ve...
I recently received an replacement 7960 phone from Cisco. When I connect it to our network, the phone hangs at 'configuring IP'. I am not able to issue an erase on the phone by using **#. I...
In this environment there is a Cisco Catalyst 2950 which needs to have QoS implemented on it as there will soon be VoIP traffic traveling on it. I have implemented and verified QoS settings, ...
our company would like to have soft phones on there laptops. right now we have cisco callmanager 6.1 but we do not have a presence server nor the budget for it. so i am just looking for a go...
I need to configure an FXS port on a cisco router to link to our paging system.
I have configured the dial-peer, and it works, however the user needs to enter the "zone code" (ie: 03...
I have recently upgraded to an ECS motherboard (GF8200A) which happens to use IDT Sigmatel audio.
I also have a Philips VOIP321 Dualphone which hooks up to my computer and I use frequently ...
Our Current Version of Call Manager is "Active Version: 5.1.1.3000-5 " I have inherited the IT position at the facility and can get into the box but because of a server failure we are working...
have recently installed a ShoreTel phone system and setup a standalone Windows 2003 server virtual machine to run the voicemail/application server software that comes with the phone system.
I can't receive incoming calls on my Cisco CME setup. When someone calls me they get a dialtone- if they enter an extension at that point the phone will ring. How can I make it so all the phon...
I have a Cisco voip lab at home and I have one major problem, hopefully someone will be able to help me out or point me in the right direction at least...
I have a Cisco 2620XM CME router and...
This question is regarding Cisco Call Manager 5.1
Can I Sync Call Manager User Profile with Active Directory [Windows Server 2003].
So that I wouldn't have to manage and maintain u...
OS: CentOS 5
Asterisk version: 1.4
Asterisk server IP: X.X.X.X (public IP)
X-lite IP: 192.168.10.1(private IP)--behind NAT
I am trying to configure asterisk with X-lite using broadvoice ...
I'm setting up CUCME on a 2851 running IOS 12.4(9)T7. I set up the phone loads and uploaded the firmware files, but the two phone types I have, 7941G and 7911G aren't liking it. The 7911's loo...
I have a project that I am trying to acomplish.
Three Main Goals
1. Enable a small business to have a full featured Asterisk PBX for 4-6 lines (analog from verizon, sbc, etc)
many ex...
Ladies and Gents, morning.
My scenario is this I have 4610sw phones, avaya voip. They reside on vlan 1 pc are connected through the phone vlan 2. To allow this the switch port is trunked ...
