my solaris 10g netstat -s -P tcp output shows
netstat -s -P tcp
TCP tcpRtoAlgorithm = 4 tcpRtoMin = 400
tcpRtoMax = 60000 tcpMaxConn ...
I need to update the subnet mask on my UNIX box. Which file should be updated?
I need to find out how many network cards are active or installed on a Sun Unix server. Could someone tell me the unix command to use to display this info? I can't use SAM because I dont have ...
I am faced with a problem that the sharetab file is missing on a server after a restore usnig Veritas Netbackup and BMR. We are investigating this problem.
I would appreciate if I could get...
have solaris 8 running on sun blade 100. need to change tcp/ip config. i edited /etc/hosts to new hme0, but don't see where to put subnet mask.
I am not expert of UNIX, currently am trying to move jobs on solaris 8 to solaris 10...
There are some jobs those are using "ftp" to transfer files like below..
ftp -niv
but whe...
Segfault occurs after trying to SSH out of CentOS
I have two seperate networks that are seperated by a T1 connection. The T1 is working as it should, the two networks are controlled by layer 2 cisco switches, there two solaris servers server1...
I have a sun blade 100, running solaris 8. I have a static ip address in firewall natted to 192.168.xxx.xxx range. The trusted side of my firewall is 192.168.xxx.1. That would be my gateway...
I have an iptables firewall. I have several networks connected together. I'm trying to debug a packet which is getting lost.
I have logging rules at the beginning and end of ALL chains....
I know this might be an obvious one, but I've been doing a workaround for sometime now, but I'd like to find out how to allow root access between servers.
Scenario:
Got a RH server and w...
How can I add permanent ip route in Unix.
Fuad
We have installed Gateway for NFS on a Server 2003 R2 file server and attached a drive letter to an NFS NAS device on site. From our client machines we can successfuly map to it and see it via...
I wanted to extract file25 from tape on /dev/rmt/3m on serverA(no space) to serverB(space). The reason I need to do a SSH is space related.
A) The following allows me to read from SERVERB...
Any recommendation for this upgrade, I found many problems after the upgrade:
After I upgraded to Apache2.2.13, my site is returning 401,
problems with SSL connections ,
We have upgraded...
We have a client who is running SAGE (medical billing) off of a custom built SCO UNIX machine. There are several IBM terminals running off this machine.
The client now also has a properly con...
We have scheduled 5 files to be moved to a unix box in an interval of 10 mins each.
We sometimes get the following error , not always though and one particular file fails the remaing files ar...
