How do I list all the DNS records for a domain?
Asked by: javajoe74
is there a way I can get a list of all the dns records (A, CNAME, MX, etc) associated with a domain?
I tried using nslookup, then "list mydomain.com" but nothing. I know there must be some simple command either in Win or Unix that will allow me to do this.
2006-05-03 at 08:13:37ID21836533
all
dns
records
list
domain
Unix Networking
  1. CNAME to CNAME?
    Is it possible to point a CNAME to a CNAME? Here's the requirement . . . I have hundreds of customers who I frequently move between different servers so I want to set up www.<theirdomain>.com to CNAME to a single A record on my domain which I can then change to move th...
  2. CNAME in MX record (Urgent)
    I failed to send mail to "cficarbonfilm.com", after i do the mail test in the www.dnsstuff.com, it shows the below content. I dont understand whta is means. Any one can kinldy explain it to me and any advise? Many thanks. I am new to MX and DNS. Getting MX record ...
  3. NSLOOKUP will not resolve MX records
    How do I troubleshoot not being able to resolve MX records using NSLOOKUP?
  4. i have same issue my mx record id mydomain.com
    i am facing same issue ... i have created my mx as shown below mydomaini.com MX preference = 10, mail exchanger = hit-hts.notsameasmydomainname.com hits-hts.notsameasmydomainname.com internet address = 10.10.10.10 please detail how do i fine tune my mx entry... do i n...
by: ravenplPosted on 2006-05-03 at 09:34:17ID: 16597781
First of all, the DNS server have to allow for listing entries, and or security reasons it usually allows that only to dns slaves (and slaves for noone).
host -al domain.tld dns.server.for.domain.tld
by: patspamPosted on 2006-05-03 at 18:01:20ID: 16601892
Or alternatively, if you can running the DNS server yourself in BIND examine the dns files, usually located in /etc/namedb
by: ravenplPosted on 2006-05-03 at 23:48:44ID: 16603184
Or another alternative: puth that IP into /etc/hosts
by: gheistPosted on 2006-05-04 at 14:34:48ID: 16610079
> is there a way
do as many DNS lookups as types of records.
Each DNS server returns different data under ANY class of DNS request.
There is no command on UNIX, nor in Windows.
by: NopiusPosted on 2006-05-05 at 22:41:27ID: 16620144
there are two possible ways to understand your question:
1) How to list all records below some domain name.
Usually it's done from interactive nslookup mode, not from batch mode
nslookup - your_dns_server
>set q=any
>ls -d domain.name
listing  may be prohibited by administrator or by firewall settings, in that case you get empty output or 'not implenented' errors.
2) How to get all records of the domain name itself.
in that case you need to run
on Windows:
nslookup -"set q=all" yourdomain.com
onUnix:
nslookup -q=any yourdomain.com
by: NopiusPosted on 2006-05-05 at 22:43:34ID: 16620152
and I aggree with gheist, 'set=query=ANY' may be unreliable if run against different servers.
by: ahoffmannPosted on 2006-05-06 at 11:48:42ID: 16622504
use ls command in nslookup, if that does not return the list you have to ask the admin of the DNS server
anything else is guessing
by: hiteshgupta1Posted on 2006-05-11 at 00:00:02ID: 16655781
at least not in UNIX
by: ravenplPosted on 2006-05-11 at 00:07:57ID: 16655814
what about mentioned in very first comment
by: The--CaptainPosted on 2006-05-12 at 14:11:44ID: 16671313
Stop saying that!  It's simply not true.
Of course there is a simple command, given that the remote DNS server that hosts the zone is willing to transfer the zone to you - it's:
dig @primary-nameserver.example.com example.com axfr
Which effectively downloads the zone as if you were a secondary nameserver.
Cheers,
-Jon
by: ahoffmannPosted on 2006-05-13 at 12:32:11ID: 16675002
as Jon and I (see http:#16622504 )said, the DNS server has to allow a listing
then nslookup, dig, some others kan list the domain on any OS and on windoze
by: ravenplPosted on 2006-05-13 at 12:34:16ID: 16675008
OK, now I'm feeling ignored (see my very first comment).
by: ahoffmannPosted on 2006-05-13 at 13:12:09ID: 16675116
oops, host is a valid solution on some Unix' too
by: The--CaptainPosted on 2006-05-14 at 02:10:33ID: 16677051
yup, raven deserves some serious credit here (I was not aware of such a usage for the 'host' command - it still seems overly verbose compared to the similar dig command).
My apologies to raven,
-Jon
by: JustUNIXPosted on 2006-08-04 at 05:41:23ID: 17249452
Try this:
# dig mydomain.com axfr
As already said, access restriction may apply.
If you don't have dig on your Unix box you'll have to get it from the different sources (tell me which Unix brand you have and I'll point you to the correct location).
For Solaris (SPARC or x86) this would be http://www.sunfreeware.com (make sure to use your closest mirror).
by: The--CaptainPosted on 2006-08-05 at 00:16:03ID: 17254980
JustUNIX - thanks for duplicating my advice without giving credit.
Cheers,
-Jon
by: JustUNIXPosted on 2006-08-07 at 00:07:41ID: 17261774
Sorry Jon,
I've not seen you posting (maybe, I was too much in a hurry that day :-(    )
You're right, the only difference ist, that you also specified a specific name server and I did not.
I apologize!
Cheers,
Hanno
by: ravenplPosted on 2006-10-04 at 23:42:37ID: 17666321
I think I addressed two major things in my very first comment: Usually You can't, and if You can host -a -l will do.
by: ahoffmannPosted on 2006-10-05 at 00:30:15ID: 17666486
agreed, ravenpl said it all in his first suggestion
by: The--CaptainPosted on 2006-10-06 at 01:38:06ID: 17674771
agreed
by: gheistPosted on 2006-10-09 at 08:05:42ID: 17691042
I agree that first answer answers everything others just sched some light on non-impostant detail.
by: JustUNIXPosted on 2006-10-17 at 03:36:35ID: 17746262
Vanbili,
a) the problem is that the command "host" (suggested by ravenpl) is not usually available.
b) nslookup is always available (as Nopius sugegsted) -- but not always reliable.
c) Using "dig" (The--Captain) would be the best (but some Unix variants don't have it either :-(  )
Therefore, all three contributed to the solution in different ways ...
by: VenabiliPosted on 2006-10-17 at 03:44:46ID: 17746297
JustUNIX,
Where you had been last 2 weeks when 4 experts made a recommendation what to happen with the question and all of them agreed?
However - I stand behind my recommendation.
On a very side note: You posted in this question for the first time 3 MONTHS after all the discussion had stopped. I am not quite sure if anyone needs a solution 3 months later. Had it not been the slip in cleanup, this would had been closed by this time.
Maybe you can try to answer to questions AND pings in time? You may find that the Askers actually return if you post when they need help.
PS: And if you cannot type a simple name as Venabili, just copy it. It does not take so much time.
by: ahoffmannPosted on 2006-10-17 at 05:27:27ID: 17746895
> Where you had been last 2 weeks ..
hey, Venabili sometimes there's more to do than EE :-))
nslookup is the most reliable suggestion 'cause available on all platforms (at least I don't know any which misses ls command there, including M$), but host is available on most modern platforms too.
by: ravenplPosted on 2006-10-17 at 05:33:22ID: 17746935
JustUNIX is little right in fact: nslookup is dropped from modern OSes. In fact same for host. Dig replaces both of them - but on the other hand dig is rather new tool and not available on older systems.
Split between those who first mentioned each of those commands.
by: VenabiliPosted on 2006-10-17 at 06:26:31ID: 17747380
ahoffmann,
It was not for you :) And why I hear this line always less than an hour after my comment and always from people that had been not answering for days/weeks/months and had just realised they do not take points? Nothing personal - just observation... :) Kind of strange, isn't it? :) And actually you DID agree to the award to ravenpl?
ravenpl,
I would agree for the dig but it was ahoffmann who mentioned it. JustUNIX came too late and did not really added new information...
by: JustUNIXPosted on 2006-10-17 at 06:38:39ID: 17747485
As you see before, I did never say I deserve points for answering -- as three others contributed earlier.
by: ahoffmannPosted on 2006-10-17 at 06:51:57ID: 17747580
most of the thread goes about "who's right" or "who was first" and no experts insist on being the most correct, as usual ...
Venabili, you got all the information, make your descission.
If totally unsure, ask the PE here, who will vote for a split now, I'm pretty sure ;-)
by: The--CaptainPosted on 2006-10-17 at 13:27:45ID: 17751823
No, it was The--Captain that mentioned it
As long as we can arrive at a consensus, I don't care what happens.  IMO, the bottom line is that there exist cmdline solutions for zone transfers, and raven pointed that out first.
Cheers,
-Jon
by: VenabiliPosted on 2006-10-18 at 03:50:47ID: 17755566
Guys,
I asked what to recommend. 4 of you said "award ravenpl" (including the PE). I decided to agree with the 4 of you . And now we have all this again... This is what really confuses me - if it wasa direct recommendation, I would most probably be back reading and reading again but after a ping and supposedly agreeance of everyone?
by: JustUNIXPosted on 2006-10-18 at 04:00:54ID: 17755612
OK -- to finish this up:
ravenpl pointed out that there is a cmd available (host). So he deserves the points.
I only wanted to add that there is more than this and it will not help in many cases ...
Sometimes, Unix has many different ways to offer for sultions -- and the many variants
(including a whole vast of Linuxes) add to this.
by: The--CaptainPosted on 2007-01-25 at 16:03:07ID: 18400809
I agree - pts to raven
Cheers,
-Jon
by: percunoPosted on 2009-11-05 at 11:50:58ID: 25753208
Given that this thread is 2/3 years old, I am finding it hard to reconcile the comment by ravenpl  that nslookup and host have been "dropped" by most modern OSes. Can you clarify on this ravenpl?
I use Windows XP, Vista and 7, RHEL 5.3, Fedora 11, and Ubuntu 9.x, as well as an older Fedora 4 box that is soon to be obsoleted, which pretty much covers* the range of commonly** used modern OSes, and every one of them still have both commands. I agree that dig is better, but doesn't exist on Windows of any flavour that I am aware of, and sometimes you don't need all of that information anyway. When it is needed, it is a godsend.
* given that RHEL/Fedora/CentOS and Debian/Ubuntu are the most prolific major branches of Linux
** as in many tens of thousands of users or more.
