I have configured PF on a FreeBSD 5.4-RELEASE machine as follows:
===== (/etc/pf.conf) =====
ext_if="rl0"
int_if="fxp0"
int_net="10.0.0.0/8"
ext_addr="24.129.135.46"
rurouni_addr="...
how to changes ip addresses for the boxes in the following unix flavors?
HP-UX 11i,
FreeBSD
Red Hat Linux AS 3.0
Hi Experts,
I've been using windows for ages now. Suddenly, I decided giving a try to linux. I'm experiencing some problems though regarding the LSMOD command. I know what it does but it lo...
I have a FreeBSD-Box (6.1, without X) which I'm accessing both locally and remotely through SSH.
Locally, I executed portmanager on the first console. My problem is that portmanager takes ...
I'm trying to setup samba. It seems to me that the smb.conf is ok.
But I'm trying to connect to another host in the Windows Network to list its shares, but I just receive the message...
Is there any way to print from HP-UX to an HP Color Laserjet 3600n? After I bought the printer, I found out that the jetdirect card in it is not configurable in the HP-UX Jetdirect system.
Hi All,
I am running Solaris 8. I create the following script under /etc/rcS.d/S99ndd to force the server to run at 100MB full duplex mode.
#/bin/sh
# force ce0 100M Full Duplex
/usr/s...
This is a follow-on to an earlier question at: http://www.experts-exchange.com/Networking/Unix_Networking/Q_22560258.html
I'm pretty convinced I want to setup SSL on each Linux-from-...
OS: Solaris
Product: Mostly jumpstart
Just to make sure this is documented as I've seen this error on many forums without a working solution:
tftpd[]: [ID daemon.error] socket (delay):...
Hi all
I have postfix and Cyrus on FreeBSD. It has been running rock solid stable for years.
I need to create a new email account that access email via IMAP from within the office and ...
Hi all!
I have a question that's bugging me!
Does anyone know why the /etc/hosts file on a Unix system is NOT case-sensitive?
As we all know, Unix systems are case-sensitive, so I won...
I am receiving the following error when trying to print on an IBM machine
Printer Support Not Installed
Type or select a value for the entry field.
Press Enter AFTER making all desired ...
I have a problem with acessing Sco Unix thru a cisco vpn.
On internal lan i can ping the ScoUnix box and telnet into it. However when i vpn into the office i can ping and telnet widows and ci...
How to configure GSA sharing in AIX unix servers? We need to distribute some files for all of servers?
Hi Experts,
As I work in Unix/Linux Environment and work on different projects many sources ask me if I know How to configure these two. could some one Please guide me on this?
I added a new group and assigned users. While on the Solaris server everythings ok but on a Linux client in ls -ltr I can see the group id instead of groupname.
The groupname is not recognize...
What is static route and dynamic route on a unix box...???
and
what are iptables , firewall , router , switch ???
Can you please let me know How to restart apache services in unix
I have a Fedora 10 box on the lan at work. I am using the same DNS server as my windows box and the same DNS server as about 100 other people in the buildng. None of which have a problem wit...
I currently have 1500 users, and growing, and seem to be experiencing DNS related issue causing a degradation of service. At peak times, clients on the largest VLANs cannot get to the DNS (of...
I have a Arris CMTS 1000; with a new Centos 5.2 DHCPD (3.04) server. I am trying despirately to hand out IP's to cable modems and there are three different MAC subsets that refuse to bind. T...
We have scheduled 5 files to be moved to a unix box in an interval of 10 mins each.
We sometimes get the following error , not always though and one particular file fails the remaing files ar...
I'm new to unix shell programming. I was wondering if there is a way to use if/then statements in crontab? If so, can you please give me an example, or the problem I'm working on is ...
After much diddling, I give up. I need help setting up ssh forwarding. I have my work PC runing xp (mandatory), a number of bastion servers and remote hosts I need to ssh to. The bastio...
here are the steps I've taken in sloaris 10:
1. Created user dir under /export/home/guests/myuser
2. gave ownership with chown
3. created user with useradd with -s /bin/true option
4. gave...
