Time Tested Unix Networking Solutions: 26 - 50 of 282
I've been trying to setup a FTP user on our HP-UX 10.2 Unix box. I want to create a user account that has a password. Once the user logs in they will have access only to their root directory. ...
OpenBSD 3.2 trying to add a route to my freebsd box thats on the same hub... with FreeBSD i get it to work just fine but with OpenBsd its a bit different and new to me # route add domain....
Hi, I have a huge list of domains(one per line, in a text file) and all I need to do is to check if this domain exists or not. If it exists, the domain should be printed on stdout, so I can...
Hi, What I'm trying to do is that while keeping TCP connection alive, a client send some data to a server from time to time. So, I decided to use select() at a server side to read dat...
Hello! I have several domains hosted on my nameservers (BIND 8.x). Everything works fine, except that for one of those domains I have following records in my logfiles (both, on master and o...
Hi, I need to resolve the hostname using the IP address. I can't use NSLOOKUP as it is using DNS but the machines I need to query are not registered in the DNS. I need to query the machine di...
Until now I have succesfully used proftpd in non passive mode without any problems. I now want to connect in passive mode to the ftp Server. There is of yet no firewall,I just want to set th...
Our NT network has a firewall which is a Unix machine. When I use TRACERT command inside the network, I can only trace upto the firewall and get the message: Tracing route...Destinatin host un...
Hi, I understand that WGET is used for downloading files from a remote. I am trying to UPLOAD files from my local hard drive (laptop) to a remote ftp server and am trying to avoid the usual...
What is the difference between subnets 255.255.255.192 and 255.255.255.191
Hi All, We have one 10 years' DEC Unix box (brand: Digital). Want to change its IP address. Besides looking the file in /etc/resolv.conf /etc/hosts /etc/defaultrouter /etc/netmasks ...
Hello, I need to connect from a Sun Solaris v9 to a Windows 2003 IPSwitch FTP Server using FTP over SSL (explicit encryption). Do you know what client can I use in the Sun machine? or can I c...
Running openssh, how do I allow only specific hosts or IP addresses to connect to the ssh server? Can I allow telnet and ftp access to certain users but block the same users from logging in...
Hi Experts: I need to map my windows 2000 box to a NFS share on UNIX server. I downloaded and installed windows services for UNIX 3.5. After reboot, I can see my NFS network. However, when ...
Hi I have vsftpd running on RedHat AS 4 with vftpd. I have a few users uploading files to the www root. I can't figure out how to get the local_umask and file_open_mode to work to give my user...
Each time I run the command "yum install freetds-0.63-1.1.el3.rf.i386.rpm" the I receive the following error and the .RPM is not installed (after I check the Yum install list): Loading "insta...
We have a very weired IP duplicate problem in our customers network. All the solaris and HPUX machines received same kind of error messages like below: *************************************...
Each time I run the command "yum install freetds-0.63-1.1.el3.rf.i386.rpm" the I receive the following error and the .RPM is not installed: Loading "installonlyn" plugin Setting up Install ...
Hello all, I just got assigned to this 'little' task of solving a Samba conflict my department has had ever since XP came around. (the previous lab tech who set up the server got assigned else...
I have a system integration issue a with group of systems configured in failover. The behaviour of the COTS product in failover is to use the fallback system. However, if the primary system re...
I have a server with unix solaris 10, with multipathing is configured, and I want to test it, however it is in different location, so I want to disable a single network interface, while sniffi...
How do you open an .exe file on Unix to view the file?
Where would I place a "route add" command on Solaris 2.8 so that when the box boots up it enables the route.
I am not really familiar with SCO OpenServer operating system. I managed to know a little command like SCOadmin after browsing through the Internet. This company is running Medical Manager pro...
 Hi all...This is my first post so be easy on me =)   OK here goes...We have a client that has a Medical Manager UNIX Box. They are currently in the process of buying a new server. The ne...
