Hi experts,
what is the linux kernel parameter that defines the TCP queue size? In solaris it is tcp_conn_req_max .
But I want to know what is that parameter in linux?
I have two identical Sun servers running Solaris 8. Both of these servers are running an application (webMethods) that needs to access a remote DB server. One of the Sun servers can ping, te...
Need NetGurus help here.
I am investigating on couple of network issues.
1. I see that for one of my server , interface outbound err rate is more. I would like know from which other host...
I am working with Solaris 10 x86 on an HP DL360. I am trying to write a simple script to use sftp to download a directory tree.
The files I am trying to get are buried under 5 or so direct...
Hello!
I want to mount a windows share which is allowed access for all to a Solaris /mnt folder!
I want o enter username/password 1 time and then windows share folder to be mounter in a ...
POSTFIX MTA
with reguards to the variabe "relayhost"
relayhost=smtp.host1.com, smtp.host2.com ect ....
1)
Can someone explain the process in which Postfix relays to multi smtp.hosts....
When I tried to access the server from a PC on one segment of the firewall (routing on firewall), we are unable to ping to the server even through we have allow it in the rules.
When we tried...
I have a Sun V440 box, with Soalris 9 ,set up for interface redundancy using multipathing, as follows:
lo0: flags=1000849<UP,LOOPBACK,RUNNING,MULTICAST,IPv4> mtu 8232 index 1
ine...
I m login as root and tring to perform following command
chown -R raza mypath/dirnet/test
chown: mypath/dirnet/test: Not owner
how do I change a directory ownership
I have ws-ftpd 2.6.2 installed on my Solaris 10 systems. Whenever I
ftp to this ftp server and do a "dir", it returns the following
errors. Do you know what am I doing wrong? thanks!
This question is related to TIME_WAIT state and its difference in functionality across platforms.
I (1)create a socket , (2) bound it to a port , (3) connect it the client
socket...
I'm looking for the sources of ifconfig for solaris
does anyone know where I can find them?
What is the maximum number of sockets allowed to be
opened concurrently in Solaris ? Is this configurable ?
How is it configured ?
my solaris 10g netstat -s -P tcp output shows
netstat -s -P tcp
TCP tcpRtoAlgorithm = 4 tcpRtoMin = 400
tcpRtoMax = 60000 tcpMaxConn ...
Can we set schedule to copy files from unix to local harddisk?
How?
The timeout setting for ftp on my machine is 900 seconds, I'd like to change it to a longer time, how do I do this?
Thanks in advance.
I am using CoreFTP lite to connect to my FTP server in passive mode and I get something like (I am not behind a firewall):
Connect socket #660 to 66.117.23.50, port 21...
220 ProFTPD 1.2.1...
I am not able to restart the service
sudo service network restart
please find error
sudo: service: command not found
Could you help me where to get free HDLC source code (written in C, C++ ...)?
I would like to use "SED" command to count number of rows in one flat file. Can I use it ?
Thanks for help
Sridahr.B
Hi...
I have a squid cache configured for transparency, i want to have a setup where i will be able to let my squid send the IP Address of the client not the IP address of the squid. in su...
I am faced with a problem that the sharetab file is missing on a server after a restore usnig Veritas Netbackup and BMR. We are investigating this problem.
I would appreciate if I could get...
On Solaris...
1. How do I find out what process is holdnig a socket?
2. How do I find out what sockets are being used by a process?
Thank you.
I did a top command in Unix solaris:
cal anyone tell me what is the agent process? and what is the purpose of it?
PID USERNAME LWP PRI NICE SIZE RES STATE TIME CPU COMMAND
I just installed a SUN Directory server 5.2 in Windows server 2003, and tried to access the LDAP directory from my Outlook 2003 client, but got an error saying - "Invalid DN Syntax (34)".
A...
