Time Tested Unix Networking Solutions: 76 - 100 of 283
have solaris 8 running on sun blade 100.  need to change tcp/ip config.  i edited /etc/hosts to new hme0, but don't see where to put subnet mask.
I am writing a shell script program in Unix that is getting multiple files from an ftp server. I want to use the MGET command to get multiple files from the ftp_server and I want to get all...
Hi... Sparc-10 client and Sparc-20 server, both running Solaris 2.4. Periodically we see the folowing errors scrolling across openWindows on the NFS client.... Apr  6 10:09:30 nfs-client unix...
I need to update the subnet mask on my UNIX box. Which file should be updated?
Under NT I have written code to use named pipes for interprocess and network communication. In Unix I know about anonymous pipes between processes on the same machine. Can I use named pipes in...
Hi everyone, We are running SAMBA 2.2.2 on a SCO UnixWare 7.1.1 server.  Access to the shared folders seems to be quite quick for our machines running Windows 9X, but when I tried accessing...
Every Sunday, My SCO openserver 5.0.4 (which I use for email accounts) reboot's itself for some reason. My problem is that when It reboots, it goes into the shell for there is no one to hit th...
How do you setup a syslog rotation? Thanks!
I need to find out how many network cards are active or installed on a Sun Unix server. Could someone tell me the unix command to use to display this info? I can't use SAM because I dont have ...
I am aware of how to change the configured CLOSE_WAIT time from its default in Solaris, HPUX, and Linux.  What I would like to know is how can I see how long a socket has been in a CLOSE_WAIT ...
How can I setup rsh on a linux server? (I am root and the linux is Red Hat ver 6.1)
We run a Windows Network with web accress via ISA2000 on a proxy server. Our new proxy server (192.168.1.28) replaces an older unit (192.168.1.21).   Our major applications are on SCO 5.05 ...
Hi I have a centos VM that I'm using as a dev server to which I can connect using both dreamweaver and winscp over sftp. When the vm is freshly launched I can ssh into the bash shell using ...
Does anyone know the if there is an LDAP search filter string syntax for searching on a multivalue attribute?  If so, what is it?  I don't see it in RFC2254.
rcp userid:hostname:/source /destination the above command gives the following error:- remshd: Login incorrect i have taken care of entries in .rhosts and hosts.equiv. the userid on b...
One Ultra2/2x200 is connected to a Ultra1/167 via a 3COM 100Mb switch. Both machines are running Solaris 2.5.1, including all recommended patches. On the Ultra2 I am running ARCserve/OPEN for ...
I'm trying to configure my DNS server to redirect request to example.com to go to question.com/path/to/directory. In the domain file I have: example.com.        IN       CNAME      que...
I'm trying to use the HideFiles directive of ProFTPd to hide all dot files except for .htaccess and .htpasswd. I've checked the documentation, but it doesn't offer much of an example regex ...
192.168.0.2 is the machine on the network that is the gateway to the internet 192.168.0.19 is the static address of the machine I am trying to configure I tried: sudo route add default g...
Our network admins are complaining that some of our AIX servers are referencing obsolete DNS servers. However checking /etc/resolv.conf I see that the correct DNS servers are listed. As the s...
Hi, I want to add/delete a entry to/from unix routing table, using ioctl(..., SIOCADDRT, ...). I am using SunOS 5.6. Can anyone give me an working example of such program (URL is als...
I am trying to automounting a samba filesystem using autofs. It is not working Currently here is my setup. Red Hat 9 In my file  /etc/auto.master /misc  /etc/auto.misc  --timeout=1 ...
I manage a couple of small servers that have multiple domains pointing to them (one is BSD the other, for the moment, RH Linux but will move to BSD when i get that one right). At the moment...
I configured Squid 2.5 on Red Hat 9 and works well. Outlook  clients not working for checking POP3 mails.?
HI All, What is backhole? How to create a backhole for a specified LAN segment / host? Thanks
