What do you think about Windows 7? Write a review or a how-to about Microsoft's newest product and earn unlimited points!
Time Tested Unix Networking Solutions: 126 - 150 of 282
I have a unix printer which wont print via a printserver box on a windows 2003 network Unix is called chequeptr this is set up in dns as chequeptr and connected to printserver called PSDE...
We are a pharmacy that runs UNIX.  We use scoserver.  We do nightly backups that sometimes fail, sometimes don't.  I would like to create a real time mirroring or at least a dependable backup....
Using netstat on Solaris I can see the connections but not the users that own the connections. Linux's netstat has an option -e to show which user owns which connection. How do i do that on So...
Is there any way to take an LDAP directory's username and password and integrate that with an htaccess file?  For instance, let's say that I want the files in /usr/local/public_html/protected ...
Abend in NDPSGW.NLM happens sporadically and seems to be unpredictable with all avenues so far.   Here is the abend log. Any Suggestions? Novell Open Enterprise Server, NetWare 6.5 PV...
We've got a user who'd like to mount some of the directories from his Windows XP Professional system on his Solaris 10 system.  Any suggestions?
Segfault occurs after trying to SSH out of CentOS
I am configuring Network Interface Card of Solaris 2.x using ifconfig in creating logical IP Addresses. ifconfig IF:N ip-addr netmask ifconfig hme0:1 180.30.60.25 255.255.0.0      .   ...
UDP
I m working on a UDP server. I have two UDP servers running on host A on port 12222 (using REUSEADDR) and I have two UDP clients (on host B) sending messages to port 12222 on host A. However o...
Hi All, I am trying to connnect to a Solaris machine from a Windows Machine. I am using Exceed to connect to server ao that I can use the Xwindows over network.. I have a problem running ...
hi i have little problem, i have windows server and AIX unix server. i have to copy files from windows to unix server,only allow ssh or scp , there is no command prompt available in wind...
Distro: Fedora 5 updted from Fedora4 via Yum hplip: 1.6.6a-1.1 sane: SaneTwain interface for windows Scanner: HP PSC1510 All-in-One scanimage works locally with the following syntax: ...
I have a laptop with Linux, I would like to use the Verizon VZAccess USB device to connect to the net.  Are there drivers available?
I have been seeing this problem on couple of our NIS+ Solaris client machines. The user home directories are on our file server and using automount on the client side, users log in to their ho...
Hi, I am setting up an FTP server with my ISP. They are going to charge me for all data RECEIVED but all SENT data is free. I am trying to work out the PROPORTION of SENT data to RECEIVED da...
I have setup networking via a 100M ethernet hub between my Sparc Ultra-5 and nt laptop. All communications seem pretty fast, i.e I can access a html port on the sun server from the nt laptop a...
Hey everyone,   Well I am running into a small problem with the tape back up that I am trying to do.  My system went down and I was backing it up however I know get an error message when I ru...
I have configured a samba server on machine A I have configured a samba mount command on machine B Both machines are CentOS-5.2, that claim CIFS support is built-in to kernel. Kernel is: 2....
ssh -f -N -L 2222:myremotemachine.com:3333 myremotemachine.com Specifies that port 2222 on the local (client) host is to be forwarded to myremotemachine.com:3333. This works by allocating a ...
I am a Samba / Linux novice, you've been warned :) Several months ago I set up a file server running FC4 which could be accessed through smb to all our clients. No passwords / authenticati...
Hi All, I recently downloaded the Enterprise edition of Real VNC v4.2.7 from the realvnc website for HP unix. The actual filename is vnc-E4_2_7-parisc_hpux.tar.gz My goal is to intall t...
I manage a box running HP-UX B.11.31 U ia64. I am new to Unix and I have not been able to find a step by step guide for installing snmp on HP-UX 11.31. Googling has suggested that I need...
Can somebody please help as to how I can allow users to use the command. when the users are using sar -d it says sar: can't open /var/adm/sa/sa19 No such file or directory This is happening...
Server version: Oracle HTTP Server Powered by Apache/1.3.19 (Unix) The Operating System Level is: AIX 5100-05 ; Running Oracle 9ias Problem:  One agency we have been supporting and maintai...
i am trying to do the folowing.. a)  i want to log all my sendmail related logs to a seperate file, not the syslog file in my /var/log dir b)  what do i need to do to start everyday a new ...
