Time Tested Unix Networking Solutions: 151 - 175 of 283
Does NIS on solaris and HP-UX supports Password aging? I have Solaris as a NIS master server and it uses shadowing (/etc/shadow). And also the HP-UX as another NIS master server.         As ...
I am new to sendmail and mail. Only recently I got chance to touch them.  I want to automate the process of sending some regular system-related emails via an UNIX box ,  so that I can notify ...
I am having problems getting the PPTP client to function correctly in FreeBSD, and wanted to know if anyone has successfully done so.  Here is the scenario: I have a PPTP VPN setup at work ...
I have a SCO 5.0.5 server running a point of sale system.  (At the moment it is independent in as much as the POS uses only Unix).  It is connected to my WinXP office network through a 3Com 24...
i want use UNIX to send an email. I want add attachment too. As what i know, "mail" command cant do attachment like attach a text file. But "mutt" command can. My problem is let say ma...
I am working on a script that controls remote processes on a distributed system.  The script executes a program on the remote host that starts processes using fork/setpgid and io redirect.  Wh...
I am trying to install FreeTDS (ftp://rpmfind.net/linux/dag/redhat/el3/en/i386/dag/RPMS/freetds-0.63-1.1.el3.rf.i386.rpm) to my server via PuttySSH (http://www.chiark.greenend.org.uk/~sgtatham...
Hi guys... I've got the ifconfig output below... eth0 and eth1 are slave of bond0. bond0 totals 10G of historical traffic and ALL of it is coming from eth0. This means my secondary netwo...
How can you tell if the crontab is doing what it should be doing?
I found one thing interesting.  If I am using vi inside cmdtool, the arrow keys works no matter I am in command mode or insert mode.    But if I try the "telnet" that come with Windows, t...
what software would you recommend for wyse 60 term emulation on XP workstations I've found a few like HotVT which I really like but $39 a licenese is a little much for me seeing as I only need...
We have Xerox (BigAss Document Center) within out network... On the Unix side we have HP JetAdmin/JetDirect settings... Is it any way I can add this Xerox thru 'hppi' into the Unix printin...
We have an accounting application which runs on Windows machines through a unix emulator. On my UNIX server I would like to know how to kill a specific print job which has been qued and is pri...
Hi, I'm very new on Solais and have some expriense on Linux. I got rsh access very slow. Can some body tell me how to restart it or how to fix this problem. Thanks Yan
Hi experts, Is there anyway I could allow a set of IP address for accessing my MAC?  I would like this machine to be accessed only by my department and block it from outside. Thanks, S...
At our corporate office, on a Windows 2000 network (all computers are Win2k), there is a Unix SCO server.  I cannot ping the Unix server from any of the computers, except if I ping from the Wi...
I have a Sun Ultra 25/ Solaris 9  I am working with. I need to set up two different Class C networks on the machine and have two ports (BGE0, BGE1). I am having trouble trying to configure thi...
Hi, I would like to setup a DNS server on Solaris 10. So far I've found some material on how to do this, but nothing suggests that there is a GUI for either installing or administering. I am...
This is what I'm trying to accomplish: 1. Create a shared directory on Win2003 server 2. With Hummingbird NFS Software (Installed on Windows 2003 server) set file permissions so that AIX use...
Installed the OS 3 times, has all the current updates, but SMC tool will hang 9 out of 10 times. The platform is x86. What am i missing?
Hi, I have 2 differents machines (True Unix) on the Network. One is in TrueUnix 4.0e and has an IP adresse like 193.51..., the other one is in TrueUnix 5.1, and has an IP adresse in 10.1...
Manage SUN Solaris 8 NIS suite. Need to add additional route addresses for new clients. Problem is the "route add net" command only allows one route and the route is gone after booting syste...
How do I change the ip address on a unix box?  I have a machine that has KDE on it - I am completey new to unix systems, so I don't know if KDE sits on a base OS and you need to change it ther...
Hello, I have a program which automatically generates ntp.conf. Now my question is, if I have a normal linux pc, and I want this one to be the ntp server, what does ntp.conf look like the...
I have SCO Unix environment running Perl 5.8.8.  My project is to communicate with a SQL Server 2005 database on a remote server.  I have DBI 1.607 and FreeTDS 0.82 installed.  I can use "tsql...
