I have a program which automatically generates ntp.conf.
Now my question is, if I have a normal linux pc, and I want this one to be the ntp server,
what does ntp.conf look like the...
Recently we have been seeing some slow response to requests and found that the network connectivity speed was one issue to address. Is there a way we can monitor the network speed between the ...
Hey Experts
I have configured two Solaris machines on vmware, while connecting to each other using Telnet, FTP or SSH services i am facing this kinda problem.
192.168.10.10 for first mach...
I have been sent here with the arduous task of having someone find a solution to why our website is supposedly slow in the US. I have no way of actually knowing if it is slow in the US, what a...
I am new to sendmail and mail. Only recently I got chance to
touch them. I want to automate the process of sending some regular system-related emails via an UNIX box , so that I can notify ...
Hi:
I have an application (running on HP-UX) that needs to allow TCP and UCP through port 15000 from a client PC (WinNT station).
Is there any shareware/freeware tools that allow me to c...
Greetings,
I have a samba share in which I've blocked access to ".html" files with the following smb.conf lines:
veto files = /*.html/
delete veto files = NO
The trouble is that...
We are doing some benchmarking on a cluster running Fedora Core 1. We're having trouble getting rsh to work. (Before anyone says anything, yes, we know rsh is insecure. This cluster is not h...
Have a freebsd server with two ip address, ipaddress1 and ipaddress2.
My second ip address when I use www.myserver.com for rev dns gives the below error.
x.x.x.x[ipaddress2] PTR record:...
I am configuring a Sun Directory Server on Solaris 9. Is there a windows admin client that I can run on my XP box and talk to the directory server on the Sun box ?
Hi:
I am running Xming with Putty.
When I try to run twm in xterm,
I get the message:
Another window manager is already running on screen 0
Without a window manager, I dont have the...
In Solaris 10 SPARC server, inetd service is offline. I am unable to start the services and as a result all the network services like telnet, ssh, ftp etc.. are not running, hence I am unable ...
I have an iptables firewall. I have several networks connected together. I'm trying to debug a packet which is getting lost.
I have logging rules at the beginning and end of ALL chains....
I have a sun blade 100, running solaris 8. I have a static ip address in firewall natted to 192.168.xxx.xxx range. The trusted side of my firewall is 192.168.xxx.1. That would be my gateway...
I know this might be an obvious one, but I've been doing a workaround for sometime now, but I'd like to find out how to allow root access between servers.
Scenario:
Got a RH server and w...
We are running AIX and need a script to kill a telnet connection by user name. The syntax needs to be EVICT <Login Name>. The script needs to go find all entrys for that user and kill the se...
What are the security issues involved when CDP (Cisco Discovery Protocol)
is enabled on Cisco routers?
I am using metasend in unix and can succesfully send an email with an attachment as a word document but am having a problem renaming the document. Any suggestions?
What is the quickest way to forward trap conditions from an AIX 4.3.3 server to an SNMP management server like HP OpenView NNM?
Is it possible to install MP RAS Unix on a non-NCR box? If yes how.. Pls give me the system requirements and procedure...
I need to write a script that will run a program on a remote unix machine. I need to telnet into a remote unix server from another unix server. I am not sure how to run a programing r...
Hi All,
I need to write a batch file that I can call from the windows environment that will connect to the remote UNIX system and run a command. Currently, I have to do this manually by usin...
Hello List,
I have configured a sendmail running on debian, acting as a relay for the internal network.
The internal DNS, bind, have the MX records pointing to this debian machine.
Th...
We are spinning our wheels trying to write a script to verify a file transfer using sftp was successful. In the script we are attempting to do a put and then an ls. However the ls only prints...
I configured a new hardware with RouterOS 2.9.41 and the same configuration that the other MK that works fine.
With the original router all works great, it have RouterOS 2.9.30.
When connect...
