Calling all the text manipulation guru out here. I believe using grep might allow me to accomplish this.
I have a sourcefile.txt which could contain hundred of lines which looks something lik...
I am migrating from NIS+ to LDAP on Solaris 10 using NIS+LDAPmapping, rpc.nisd, and Sun Enterprise Directory Sever 6.0. I used idsconfig to populate LDAP to be a naming service. When I run the...
We have a SCO 5.0.7 server and a windows XP Prof client.
We are trying putty on xp system to connect to SCO using serial port.We are able to do that.
We also want to print from SCO to the ...
Is this possible? I'm using the default Terminal on OS X and using putty on windows.
Basically when I close my laptop + walk elsewhere (multiple times throughout the day) I have to reconne...
Hello Gurus,
I need to send a mail from Unix and send a link to a mail system. Could someone let me know how can i send this?
Can the same mail command to send mails be used to send as a...
I am trying to get the catalog for pkg-get so that I can install software easier on my unix box. But I get this error.
I am guessing that my box cannot connect to the Internet. I also did a...
What does the BIND 8.x.x zone statement "type stub" mean. I know what "type master" and "type slave" mean, but I can't fiqure out what the stub thing means. Thanks.
I'm having trouble getting this to work. The local machine runs solaris and is the only one with a tape drive. i'm trying to archive files from other machines (running Linux) directly i...
hi!
I have a program that checks and print system interfaces info. I run
ioctl(sockfd, SIOCGIFCONF, &ifc) to get ifreq structures (in this case I want to get interface IPv4 address). Now the...
I am using SFTP for transferring critical data of file size about 50 MB each on digital UNIX 4100 Alpha Sever from one location to another. How can I check that the data is successfully trans...
Hi All
I have a 256 kbit/s connection over a 192.168.0.0/24 network..the gateway is a natting linux server..I need some traffic shaping rules that limit the maximum available bandwidth for 19...
If I have a subnet mask and a network address, how do I find the DNS names assigned to the hosts on this subnet using c in unix?
We have installed Gateway for NFS on a Server 2003 R2 file server and attached a drive letter to an NFS NAS device on site. From our client machines we can successfuly map to it and see it via...
How can I add permanent ip route in Unix.
Fuad
Has anyone got H.323 to work securly thru an OpenBSD Firewall running Packet filter and NAT. I'm the admin of all devices (OpenBSD on a DSL with static IP). It's a Windows box behind the fire...
I am currently running Solaris 2.6 with the default 8K TCP-send/receive-Buffers and thinking to use ndd to set it 64k for a high output application. Does anyone know how to read the nestat out...
I have an application in SCO5 communicated with several machines using nonblocking sockets with TCP_NODELAY. Once in a while, it has one socket repeatly send return with EWOULDBLOCK and select...
I'm trying to convince "the powers that be", to let me set up a BIND server on Solaris over the planned Windows DNS server.
Does anyone have any input on a good argument to help me out? ...
Hi Guys,
Is there a way vis Unix script or something to execute a command or app on a Windows PC connected to SCO unix box over IP network.
Cheers
B Cunney
Tried asking this in the WinNT networking with no response yet, so I'm posting here in hopes of one.
After setting up the .rhosts and testing from one windows 2k sp3 box with success,
I mo...
Anyone have any experience wrapping the amqcrsta process (MQSeries Listener process) in inetd.conf. We are attempting this on an AIX queue manager and we cannot get the MQSeries channel to st...
Hi
I've got a handful of users on my Debian server that are FTP only, they are chrooted to their home directly (I use vsftpd) and have their login shell set to /bin/false. Their home direct...
Possible MAC / ARP problem.
This is the scenario:
I have six different networks with approx. 20 Sun servers on each network. All six networks are connected to one Sun server with dual quad...
Hi, I'm unable to connect to an external ftp server from my hpux box. The default GW of the hp box is a layer 3 switch. From the hpux box i can telnet into the L3 switch and reach the ftp serv...
I can't access my client's server anymore with FTP and I need your guys help to try and track down the problem.
I'm using WS_FTP to connect (worked before) to an ev1servers (formerly Racksh...
