where do i get Windows NT 4.0 CD iso to download ?
I'm using a TableAdapter as a source for a DataGridView in a windows form.
I've let the TableAdapter generate standard update, delete, and insert commands.
I've been able to properly use the...
Recent Windows update resulted in a failed update for: SQL Server 2000 Service Pack 4 (KB948110) and SQL Server 2005 SErvice Pack 2 (KB948109). I tried to reboot and have auto update try aga...
OK - here's a strange problem. I am trying to map a network drive to a Windows 2000 server using an Windows XP machine (computer a). I can try to use the IP address or the host name of the ser...
EE Experts,
I am about to deploy a new VB.NET application that I have been working on for a long time. All my demos for the customer have been from mine or his laptop. I refered to the MySQ...
I am having problems with my lan connection, somehow my DNS server addresses have changed to something else and i am having trouble entering some websites, email etc.
I have entere...
is there a way to use terminal server administration mode and have 5 concurrent connections
In my windows NT machine ...
when i put the url in the address bar of internet explorer ..its not working ...
but when i put the corresponding ip address of website ... the website is c...
Dear Sir,
There is One Machine X with Windows Server 2003 installer. It has one big folder named Shared which is shared to everyone with all rights.
Other 8 machines are with Windows XP ...
I have an existed system with 10 PC windows XP. Now, how can I know which kind of network it is( peer to perr or client server) without seeing the physical connection of them.
Hello Gurus,
This is my situation :
I have a building that has 4 floors on each floor a number of pc varying from 5 to 15 PCs
I need to install a networking cables , the best possible (qua...
I have experienced twice in 2 weeks, 2 separate XP workstaions take down our internet access. What happens is the offending PC sends its MAC address out as the default gateway if you look at ...
I have about 10 servers that are in the same subnet 207.169.175.xxx wiith subnet mask 255.255.255.128 and DNS 207.169.175.171
The dc of this domain is 207.169.175.173
I have a ne...
I am running vista 64 at home and I have a cable modem connected to my pc directly. Last week my internet connection started intermittently failing. I run a constant ping test to google.com...
Hi there
I have configured a new server (win 2003) with new domain acting as Domain controller. In the current environment we have NT server as PDC. I am trying to setup a trust relationsh...
I have a workstation in an office of about 40 workstations. When you open a file from a network share it will open "Read Only". If I disconnect the nic and reboot it will work correctly for ...
We have a generic 4 port modem/router assigned to us by our ISP. Currently, it is setup as a bridged modem (with dhcp disabled) and one port connected to a router for our network. How can i co...
We have a Windows NT PC with no emergency recovery disk
When we boot the PC, we get error
"Windows could not start because the following file is missing or corrupt
<Winnt Root>\system32\n...
Running windows 2003 sp2. Periodically (about every 3 days) users will start reporting that RDC applications take a long time to switch between screens 2 to 3 minutes. Normally this takes 2 t...
OK, lets go back in time...
I have a dell PE 2650 with 5 33gb hard drives, i have a failing nt 4.op server that i need to swap out to this machine. i keep getting setup could not find any ...
An XP Pro machine on our network will no longer logon on to any account whilst connected to the network. If the user disconnects from the network, logs in using cached credentials and reconnec...
I have heard that a Windows XP Pro computer has a limitation of 8 client connections at the same time. I do not know if this is true. I have however noticed that if around that number of cli...
A small, local manufacturing company purchased a used piece of equipment for their business that has a WindowsNT computer for running the machine. They want us to setup the computer to allow ...
I have 2 computers using Windows XP Pro, both of which belong to the workgroup "Workgroup". I want to be able to share files securely on both computers.
On computer1, I can see the 2 compu...
I've got a workstation with multiple network-related problems, and haven't made any headway on fixing any of them. The workstation has an onboard 10/100 adapter, and a PCI gigabit NIC install...
