Time Tested Bluetooth Solutions: 26 - 50 of 197
I'm trying to set up Nokia PC Suite on my new laptop. I installed it and it appeared to install OK but when I try to connect to my phone and select the blutooth option I get the message... ...
Blackberry I'm trying to pair via internal Bluetooth a Lenovo XP laptop to my Blackberry (Curve 8310) .  When I attempt pairing, my BB asks for "the numeric key" to my laptop.  I have tried 00...
I have a Fujitsu Lifebook T4220 with built in bluetooth networking.  It's using the Toshiba Bluetooth Stack for Windows 5.10.04 I have the Microsoft bluetooth wireless notebook optical mous...
Hi there, I am trying to send and recieve serial commands from my phone (N6230) to what is essentially an RS-232 device over Bluetooth. Basically I need to send the device a single charact...
Now I am looking for Bluetooth programming. If you know, please suggest me what program or programming language needed and please suggest me step-by-step. Basic features I want: 1. Search ...
I'm developing an application (Pocket PC 2003 / Windows Mobile 2003) which should establish a RFCOMM Bluetooth connection to a bluetooth-server-device. ( A serial interface for an older non-bl...
Hi, In my company we have a LAN to access the network and Internet. I bougth two Belkin Bluetooth PC cards and would like to connect a laptop to the LAN to have access to the network and Inte...
Hi! Can anybody help me please with some simple C++ example of using bluetooth in linux. I need to establish serial connection over bluetooth with my robot/microcontroller and send simple co...
I cannot get the Bluetooth to operate on my Sony Viao SZ5N-B laptop. The bluetooth icon shows up in the systray when enabled and shows in device manager but will not connect or allow connectio...
Hi. I was trying to compile a simple bluetooth VC++ 6.0 application which uses the WinSock library. Now the problem is that when i compile the linker throws up the error uuid.lib(bth...
I`m developing a program on an IPaq 3870 (WinCE 3.0). I want to send a datastream from one device to another device using Bluetooth. I have made it so my program establishes a Serial Port...
Hi all, I am searching for a good way to transfer a specific file to a specific device via bluetooth. I would like to create a program for this task so I am asking for some hints on wher...
Is it possible to use bluetooth from delphi(virtual Com)?
I have a customer with a Fujitsu Lifebook T Series laptop.  He has bluetooth functionality but since a crash and reinstall it hasn't been working.  I installed the drivers and am trying to use...
I have an idea I want to implement using Bluetooth technology. I want to have two bluetooth devices exchange RF data within a short range. How can I buy individual bluetooth chips and their ac...
I got this keyboard yesterday and got it to sync once. However, something went wrong and it wasn't accepting any input. So, I removed the pairing and was going to try to re-discover the device...
I recently acquired a Blackberry 8830.  I am trying to connect to my Dell Inspiron E1705.  I have the unlimited data package on the Blackberry and ultimately want to share the internet connect...
I have laptop with Bluetooth control running on XP media center OS, When i go to the options tab and check TURN DISCOVERY ON, I get an error ( Bluetooth Service Error: An error occurred while ...
My Thinkpad X40 Model 2371 is suppose to have bluetooth. I have the option to enable it in BIOS. But I have no device manager/utility in the control panel or anywhere else. I want to connect t...
At the local computer stores, I have seen devices which connect to a USB port on your PC, then connect to the USB port of a printer.  They promise to provide a Bluetooth to the printer they ar...
I am developing a client-server application in C++ to communicate using Bluetooth between a desktop PC running windows 2000 and a Compaq iPaq with PocketPC 2002, but am having problems creatin...
Hi all, Does anyone know how do we program in VB6 to bluetooth device? Is there any API available for VB6?
Hello all.. I am trying to achieve Bluetooth mobility by interfacing an 8051 compatible microcontroller with Bluetooth. I want to achieve this by connecting an 8051 (compatible microcontrol...
Hi experts i want to transfer a jpeg file via bluetooth programatically using java. i have two 7610 nokia phone. can i use object exchange? could you pls send me a good sample code? btw...
I have an HTC (AT&T) Fuze cell phone. I am trying to use it as a modem to tether it for internet access using my laptop. I can use my USB cable and plug one end to the cell phone and the other...
