I would like to know how to search for a bluetooth device, connect and transfer files between a bluetooth device and PC using Dot net. Please provide me details on this.
Does anybody know whether the MS Bluetooth API is usable from Smart Device Applications built using Visual Basic .Net 2003 and deployed to CE.Net computers? I need to be able to assign a comm ...
I think this is a well known problem with bluetooth keyboards. Sometimes I need to enter the BIOS setup when powering up my Dell XPS 410. To do that I must press F2. But my bluetooth keyboard ...
I have an SMC dongle and a Nokia 6255 phone. The BlueSoleil software allows pairing to the phone, but connection attempts to the Bluetooth serial port service does not work.
When connectio...
Hello all. I am trying to connect my mobile phone to my computer by blue tooth rather than a data cable.
I purhased a Bluetooth Usb dongle and cd from a company called Energy Sistem. This loa...
I'm attempting to perform device discovery using C#. I've found many valuable references on how to do this on the web and in books. The problem is, all of them are written assuming the progra...
Hi guys,
I am unable to pair my bluetooth mobile headset (Motorola HS820) with my bluetooth dongle. the manufacturer is Bluesoleil.
After doubleclicking for search for devices, the software ...
I would like to know what the maximum distance is that can be econimically measure between two bluetooth devices. If I have a base station, how far away will I still be able to receive a...
Hi, I can't use my Bluetooth PCMCIA device and its software (Widcomm 1.4) after upgrading from XP Home SP 2 to Vista.
I can get the update from Broadcom: http://www.broadcom.com/products/bl...
I seem to have uninstalled my blue tooth capability from windows.
I have a dell inspiron 640m
I tried installing the R82522 Driver found on the dell site
but it asks me to turn on my blueto...
Hello:
I need to develop a program to do serial communication between two PC's using Windows XP Bluetooth Stack. I have connected both PCs using 3COM Wireless Bluetooth USB Adapter, and is ...
I am struggling with acquiring full functionality with my new tungsten E2 through my home network. Specifically internet connectivity.
When I attempt to connect to the internet the Palm go...
Can I send laptop signal to 50 inch tv via bluetooth .with crisper screen that using projector(for seminar not movie) Some TV,s have usb ports and I want to connect a bluetooth receiver and se...
I have a school project where i shall make an application that sends out information at a museum to all their visitors mobile phones. I intend to use bluetooth, but i am not sure if its possib...
I have Bluetooth on my Macbook, it works well for transferring files from my Moto Q Smartphone to the Macbook, it works for transferring files between my Macbook and my girlfriends. The Bluet...
I have an HP IPAQ 214 which has built-in WI-FI, BLUETOOTH but is NOT a phone. I have a Nokia 6230i which is GPRS enabled.
I want to be able to connect my PDA to the internet when I have no ac...
Ive successfully paired the phone with my laptop but it keeps asking me intermittently .... connect to laptop - yes or no
Really annoying.
I ahd no problem on previous phones setting as...
Hi, I dont know if this is possible but, I have a PC, Windows XP Service Pack 2 with a Bluetooth Dongle. I also have a Windows Mobile 5 PDA which has blue tooth. I want to be able to make th...
I'm using a Belkin F8T012 bluetooth dongle. I've installed the drivers without a problem. The dongle is plugged into the USB port on the front of my case, which is an Antec P182.
If I m...
I have 2 laptops other running XP pro and other Vista business, both have bluetooth and i have used blue tooth file transfer successfully. Is there any way to establish a shared folder (like i...
Hi, actually I'm need assistance for my small Bluetooth project. I need to send data from VB to Bluetooth (Ericsson Bluetooth Development Kit) via RS 232. Then, the data will be sent wirelessl...
How do i develop bluetooth applns for Windows platform - for communication between Windows CE & any other Windows OS. Please respond with details on development tools & related hardw...
Hi there,
Im developing a project which I am using Python (which 2.5 is included with leopard) and Bluetooth in which I need it to communicate with all nearby devices. I have downloaded a...
Hi
I have a Visual Studio .Net 2003
but i can't find the bluetooth related files (BluetoothAPIs.h Ws2bth.h).
Please, can anyone tell where i can find them.
Regards
I'm developing a Pocket PC (HP Pocket PC 2002, Bluetooth enabled) application with .NET Compact Framework and using VB.NET as the language. This application would need to communicate with othe...
