i try to code a tool which sends files like pictures or sounds to a mobile device.
i try the code from MS Bluetooth Api and it works to find the radio and the device, but how to send t...
I have a Amilo m4438g and i want to transfer ringtones to my nokia. I dont know if this computer have bluetooth or not. Does it?
I try to retrieve RSSI based on WIDCOMM sample program BlueClient because my understanding from their document is to use GetConnectionStats in CBtIf class. I don't know when I shall call this ...
Hi All,
I am a newbie in Bluetooth programming. To start with I have installed Windows Platform SDK for Windows XP SP2. The Irprops.lib which I assume contains the Bluetooth APIs could be l...
1) in the Bluetooth Devices window, it does not show any devices, (although the device is working I checked it on another laptop). The I was able to recognise the Nokia phone ONCE - the first ...
Hi!
I have a code, which can discover devices, and return their name and addresses. That's fine. But I can't estabilish a connection... Here is the code:
(I had intialize Winsock, and o...
is there any VB code to searh for a Bluetooth device?
Experts, I have a Plantronics Pulsar 590A headset and I was very excited about using it for many things including voice recognition software for my laptop. I tend to pace when I am thinking an...
My PC MB is a Intel Pentium Model number D946GZIS How can I find out if the PC is wireless/Bluetooth capable.and if not how can I instal the system to make it wireless/ bluetooth Thanks
How can I automate copying a file from a Windows XP "Bluetooth Exchange Folder" to another nearby PC. I can do this manually. I need to automate this in C# (Or MSDOS).
I have seen many bluetooth dongles, some supporting range upto 100 meters..
My question is that if i plug in 2 usb bluetooth dongles on my 2 PCs then which
protocol will be used to...
I use widcomm software with my epox brand usb bluetooth device
I want to read device address which can be see at bluetooth advanced configuration window, hardware tab.
Can I see it in regi...
I'm having difficulty synching my Treo 700wx to my desktop via bluetooth and one of the solutions here suggested installing the latest version of ActiveSync on the desktop, and then ...
i had to reinstall an Advent T9404 Tower today which was a problem because drivers are a problem with PC World machines anyway after spending over four hours reinstalling the system and drive...
Issue is trying to set up a D-Link Bluetooth 2.0 USB adapter on a Dell Inspiron 4150 laptop. Computer is WinXPSP2 w/first gen USB 1.
The initial installation begins and completes normall...
My 3945ABG network adapter along with my bluetooth adapter has been turned off by either bios or the hardware switch. That is the message I get when I try to turn it on. Could some one give me...
I can connect my 2 PCs together via Bluetooth and see the connection in Network Connections and in the Command Prompt with 'ipconfig' However, there is no IP address assigned
Hello all,
I'm currently working on my 4th year project developing a a bluetooth network, Unfortunately even though i have the bones of the code working at home i am unsuccessful at getting i...
My goal is to connect my Bluetooth GPS BT-309 (Dell Bluetooth GPS) to my Laptop. The laptop does have a bluetooth adaptor, and is running Vista Home Basic. I have previously connect the GPS to...
maybe you know that I'm trying send some simple notes to phones from by pc via bluetooth. I asked a lot of questions but I couldn't get a clear answer. I tried a lot of things. At last I explo...
Does anyone has any idea where to find resources about programming bluetooth dongle. (it uses WIDCOMM driver)..
I want to make an app which connects to my GSM via bluetooth and than I will ...
I have a blackberry curve. I paired a plantronics bluetooth headset (mono and doesn't support a2dp), and I can make and receive calls just fine.
I have applications on it that allow me to ...
Hello All!
I own a Logitech MX Bluetooth Laser mouse that I really love. It is supposed to be used with their setpoint software, but I don't currently use it. I have a laptop and my netbo...
Hi everyone,
I'm trying to write a PocketPC2003 application for an iPAQ that supports bluetooth. I've gone through the MS docs on using winsock for this purpose and so far I have written t...
I have an IBM X31 running windows XP with inbuilt IBM Bluetooth driver.
I purchased a Motorola HS810 headset, and have successfully paired it with the PC, but the PC is not recognizing it as ...
