Time Tested Wireless Solutions: 1 - 25 of 610
After browsing through all available topics pertaining to J2ME implementation on mobile devices, i saw no issues was drawn up about mobile phone being deployed as remote control. Not pda based...
My lenovo t61p Vista just asks for some DRIVERS for "Bluetooth Peripheral Device" after I've upgraded Nokia PC Suite for Nokia N80. Din't find them on Nokia site either. Finally I've canceled ...
hi all, I'm developing for user to send and receive as well. however, nw stuck with an error javax.microedition.io.ConnectionNotFoundException: The requested protocol does not exist sms ...
I'm into new assignment of sending SMS to mobile phones, I'm just a beginner to this, so please advice me in this regard or send a VB code to do this and the hardware requirements in detail.
On XP Pro and XP Home PCs, sometimes after repeatedly repairing wireless connections, the number of the current wireless connection on a PC will go up and up. (I've seen Wireless Network Conne...
I have two Toshiba laptops (belonging to other clients), and in the Atheros Client Utility (WLAN), each one reports the "RADIO STATUS: HARDWARE DISABLED", and the option to "enable Radio" is d...
i run several dell latitude d630 laptops in office and they are all configured with an intel pro/set wireless card. when the laptops initially boot up they automatically connect to our wireles...
Windows Vista on my laptop will not connect to the internet.  It connects to my network, but has local access only.
I just bought a new router to upgrade my 802.11g to 802.11n. However I am not being able to get any of my devices connecting at above 54Mbps. The setup is as follows: Router: - Belkin N1 V...
We purchased a Cisco 1252 Access Point.  Unfortunately we made the error of purchasing the Lightweight LWAPP edition.  The exact model number is:  AIR-LAP1252AG-A-K9  We do not have a wireless...
I just recently purchased a Linksys WRT160N wireless router.  I have connected the router and made the necessary configuration changes, (changed password, setup wireless security, etc.)  I hav...
Hi I want to be able to send a SMS message from a computer straighht to mobile. I know there are websites which you can subscribe to and use their API and then they forward the message on, ...
I have a home network setup.  I have three desktops and two laptops, all connected wirelessly.  Two of them have D-Link N PCI cards and the rest have G.  I have a D-Link DIR-655 Wireless N Rou...
Experts, My son set up my wireless router and left me with the following instructions: "You need to find a way to print out a table of the IP addresses that your computer assigns via DHCP ...
I have set up a wireless peer to peer network with an XP SP2 machine as the server and a Vista Home Premium machine as the client. The network is active, both client and server report the wir...
Hi, I want to develop a small apps to read and write phone entry, calendar, wallpaper, ect to my phone. I heard it was possible through AT commands. I own a Samsung A640 phone and I use US...
Ok i Just got a WDS (wireless distribution system) working.  However I am a little confused on how the client decides to connect to which Wireless Access Point.  Here is the setup. Cable Mo...
I can't find the split function in j2me, anyone can help? thanks.
Hi All, I am a new comer in programming world, please help me.. :-) If I want to use Siemens TC35, connected to my PC running on Windows OS, do I need a driver or I use the standard mode...
I need a relatively inexpensive solution for connecting 1 laptop to a LCD Projector and 15 monitors wirelessly.  Any suggestions?  I have found a few solutions, but to get enough receivers to ...
Just installed openSuse 11.1 on my Dell D630 laptop. I can't get the broadcom 4311 wireless adapter to respond. It works just fine when I boot it to Windows. I have included the output from se...
I'd like to upgrade my modem and router to the newer 802.11n spec, even though that spec may not be finalized. I'm currently using the Motorola SBG900 which has the modem and the router built ...
I am looking for a tool that I can walk around with that measures the wireless signal strength in a building.  Does anyone know if a tool like this exists?  Looking for something that is $500 ...
I have a Netgear wireless router WGR614 http://www.netgear.com/Home/Products/RoutersandGateways/GWirelessRouters/WGR614.aspx I use it to access broadband internet (seems to be a PPP kind) ...
I am having problems connecting to my wireless broadband router, BT Voyager 2000, with an EDUP Wireless LAN card that I have just installed on my Vista computer. I have installed the Atheros C...
