http://www.dlink.com/products/?pid=313
Are these servers reliable?
For workgroup with 3 PCS.
Should I bother with the wireless feature?
hi there,
I have a wireless router which is working well, the problem is i have a long house the top end gets good wireless coverage but the complete bottom half does not.
Moving the router ...
I have free wifi at my appt complex and I want to use it for my xbox 360. Easy right? Nope... This access point is more like the ones you find in airports where they show up unsecured but whe...
Everex laptop wireless adapter shows not connected tried repair and reinstall
hello people,
im trying to find info sources for Compact HTML (CHTML), can anyone help me? If there's a tutorial or something, can anyone pls refer?
thanks
My DLink DWL-8200AP Revision B does not have an IP address after firmware 2.10 upgrade. I upgraded two of these AP using a wired connection and have the same problem both devices.
Everythi...
What is MAC Address Cloning?
I need to connect a new laptop running windows Vista premium to the Internet by sharing the existing home connection which is one way satellite broadband. This uses a direct cable feed to a P...
I have set up a wireless network using my Sterlite MT882 modem and Netgear router. I am able to access the internet on my base machine (Win XP).
When I try to coonnect to the wireless network...
I have recently bought a Linksys Wireless-G adaptor, WPC54G v3 for my IBM T30 laptop. I installed the drivers on the CD, but when prompt to insert in the card, the hardware setup wizard...
I would like to encrypt and decrypt SMS message in java using latest enryption techniques(SYMMETRIC,ASYMMETRIC) - which should be very difficult to crack or better it should not be crackable...
Hi Experts,
I'm fairly good with Cisco wireless LWAPP and autonomous. Can someone tell me the purpose of having an Anchor Controller for Guest access?
I have an existing network of
ADSL -> router -> multiple PCs + 3Com 7760 Wireless Access Point.
I am trying to add a 3Com OfficeConnetct WL-542 wifi router as a bridge / repeater to ext...
I'm using sharepoint services 3.0 on Windows 2003 server. It's installed on C drive, which is running out of room. How do I change it so that all files uploaded to it are stored on the D drive?
I have a client, which is small seminary college. The Dean is interested in blocking the Internet inside one of the classroom\library spaces. Students will need their laptops however for tak...
Hi all,
I'm trying to get our wireless application working with services from KDDI, DoCoMo and Vodafone KK. It needs to connect through to the home page of each of the services using either...
I am looking to get a wireless PCI Card for my desktop that has an external antenna.
I want to use the antenna across the apartment from where the desktop is.
I have an Outdoor XM Radio a...
how do i locate the wep on my router
i have 4 work stations and 1 server hooked to a switch then to the router
i am trying to add a laptop to our system
thanks
Hi all,
I just introduced a new 10Mbit/s line into my network, and I'm severely rusty on iptables and experiencing some trouble setting up my rules properly. I currently have three interfac...
I have set up a wireless network at my gliding club. The network is pretty simple - a Dell desktop computer using XP, and a D-Link DI-824VUP+ wireless router. Our internet connection is via a ...
I am assisting a small elementary school in setting up a LAN for students and staff. The school has comcast cable at 12 Mbps. I would like to set the school up totally WIFI because it would gi...
Any expert can tell me what are the <lac> and <ci> from GSM AT Command "+CREG=2"?
Does the phone receive these through cell broadcast?
If not, how the device know these information?
I want to configure our various cisco aironet 1130ag's to authenticate against a microsoft radius ias server. We do not have a cisco wireless lan controller. we run active directory, mostly ...
I am looking to write a java application to run on my mobile phone (SonyEricsson W800i) which can send an SMS message automatically. I have looked around the net but not found anything ...
