HI,
I have a network with 75 users and 2 win2003 servers. We would like to add wireless by using 2 cisco 1242ag WAPs . What is the best way to deal with security through the wireless setup....
I have just set up a small home (wireless) network for a friend.
Hardware
Desktop machine app. 3-4 years old running Xp Home. Has an Ethernet port.
Notebook - gericom, app. 3-4 years old r...
I got to prepare something which can send SMS from PC. or decode pdu messages in the mobile.
I found that PDUspy can do that reliablely, but I couldn't use it properly.
does a...
Is there a Blazer browser I can get for XP so I can test my web applications? I have Windows Mobile 5.0 emulator to test, but not sure how to test it will Blazer? When I borrowed someone els...
Really simple question I think, but one for which I cannot find any simple direct answers.
The environment is my test bed and is a basis for client work.
Current setup. Cable modem in ...
Hi experts,
I want to have a delivery confirmation for the SMS message I sent.
3 questions:
1) Is there any other way to get a deliver confirmation other than Status Report?
2) I...
I'm trying to build an application that can block incoming message.
I use J2ME. Can J2ME do this? I mean block incoming message from all number?
(I hope the incoming messages are no...
Hello Configuring Siemens SL45i Modem i am trying to send sms from Hyperterminal. i am sending these AT Commands.
AT [i press enter]
OK ...
I have a laptop running Windows 7.
When the laptop is at a certain location, trying to connect to an open wireless network, I only get "Local Access Only"
Another laptop in the...
I do some work for a high school and they have 13 Cisco c1200 access points. The main issue is that often times the client machines (laptops and pc's on mobile carts) come up saying that the ...
Hi Experts,
Iam having trouble getting a signal upstairs on my wireless network. I have a 108Mbps WPN824 (Rangemax) and am concerned that if I but a range extender / repeater that it may n...
I just got a new Vista Laptop, and ran into major issues trying to connect it to my outdated LinkSys BEF11S4 wireless router (another issue entirely).
I ended up getting the connection work...
Having trouble at one out of about 50 sites with an LWAPP AP that won't associate to a controller. Looking at the logs on the AP I can see that it is getting the wrong IP address when it trie...
Dear experts, I want to play sound ( wav, or whatever file ) in midp1.0 device
can I ?,
if yes how please ?
if no, how games are playing different type of sounds ?
thanks you
How to serve 3gp video files with php?
im trying:
<?php
header('Content-type: video/3gpp');
header('Content-Disposition: attachment; filename="video.3gp"');
readfile('http://server....
I need to connect my airport express to my existing wifi network.
I cant connect the airport, wont accept the network.
I use WEP with 10 digit
How to do????
I have 2 laptops, an old one and an Amilo Li 1818 running vista "ultimate" (no service pack/ windows update up to date). A new wireless router netgear wpn824 v3 is allowing internet access on ...
I have an XP Pro machine that lost its internet connection a few weeks ago. A wired connection is not an option for this machine. Wireless connection shows it has a strong signal from my acc...
Hi all,
I have created an audio capture player within my MIDlet using:
player = Manager.createPlayer("capture://audio");
I am then recording using the RecordControl object that is obt...
Whats the best search technique to use to loop through an Enumeration instance which contains 100 or so Contact objects from the JSR-75 PIM API.
http://www.j2medev.com/api/pim/javax/microed...
hello all,
When i try to connect to my wireless adapter through my notebook i can only manage limited or no connectivity status. I checked the system eventg logs and found Event ID 11197: Th...
I would like to share my Internet connection with people in the guest house (located 80 feet away).
I do not want to run a cat5 cable from my house to the guest house.
Right now, I hav...
I am looking to create a desktop shortcut or a batch file in Windows XP that will automatically open View Available Wireless Networks and even better also refresh the wireless network list. I...
My wireless network connection seems to drop at random. Sometimes it runs connected for 12 hours straight. Other times runs 5 minutes and drops me. When it fails my laptop network card hangs a...
Dear Experts,
I am after some hardware which will let me record my voice onto my PC wirelessly. I should be able to walk anywhere in the house and even in the back garden and still be able...
