I have a linksys WRT300N wireless router. I go to the routers web page on my network and add the two computers' MAC addresses to the Wireless MAC filter list and add both MAC addresses--the w...
The wireless card is a new Belkin 54G+ pcmcia which is connecting to a wireless B.T home hub.
I have another person also using a desktop with no internet or wireless problem so the hub...
I have a Dell Inspiron 1100 with Windows that I have connected to a wireless system & it works fine. Now I need to set up a second computer to it & it's not working. The 2nd computer is a El...
Odd one this ... in my house I have a Wireless-G 'o2 broadband' ... works well enough. Some some reason I decided to get a Linksys Wireless N router and card (WRT150N, WMP300N) and attach it, ...
Hi!
Something has happened and my wireless connection doesn't work. I tried to update the driver but I got an announcement that there is an update but there was a problem with installing it...
i just secured my network at my house and it use to be unsecure. I have 4 computers and i got 3 of them online but one of them says its connected but it says its only getting a 2% signal. At...
Hi i have seen this term used for antenna description.Could u guys tell me how this type of antenna fucntions or operates?Its a Dual Polarity Antenna.
I am getting this message and don't know how to sort it out - whilst ensuring that I do not lose the conneection that I have. ( I am away from home in a foreign coutry.. Currently I am using a...
I have a very odd problem with my laptop. It's a Dell Vostro 1400 with a Dual Core and 4 GB or RAM. I run Vista Business on it and use IE8 to browse the net. It is connected to our workplace d...
I have a Cisco Aironet 1131 running (fine). To extend coverage by placing a view extra AP's. Now it seems that the 1131 can be connected, so they have one SID and central managed keys.
I was trying to do a test to friends laptop Fujitsu Siemens AMILO Pro V2000 Modelname FB21 (after he had done fresh installation to windows XP Prof SP2), with built-in wireless card : IntelĀ® ...
Can someone tell me how to properly secure my wireless router. Is there a better way than WEP? I wanna be able to connect to my router but I don't want anyone to see my signal. I know a gu...
Really simple question I think, but one for which I cannot find any simple direct answers.
The environment is my test bed and is a basis for client work.
Current setup. Cable modem in ...
I've got an ISA firewall that is on a network range of 10.2.16.xx - 10.2.19.xx. I also have several access points that I'd like to have give out 192.168 addresses through the built in WAP DHC...
We're running the Netgear wfs709tp wireless switch, which supports a captive portal for authorizing users, as well as a separate guest/contractor network. Both SSIDs are encrypted with WPA and...
I have a desk top PC, running XP series 2. It is supposed to connect to my BT Hub 2 wirelessly. Within the wireless network connection properties, network authentication it does not offer the ...
Hello -
I have an older laptop Dell Latitude C640, Windows XP SP3. With Dell TrueMobil1150 Series Mini PCI Card. Card has the latest available driver from Dell.
Router is Netgear WGR6...
Where can I download a modem driver for the Nokia 6150e?
I am working on a mobile cart for a client in a healthcare environment. They have a computer on there with a wireless network adapter as well as an Ethernet port. They now want to add anothe...
Hi Experts,
I hope you can help me as belkin support were quite un-helpful. I believe i have an mtu issue with a laptop in which it will not open some sites, yet on another laptop connected...
I have an old Nokia 5110 and the datacable. I would like my program, designed in VB.net, to send a simple SMS's containing a short text string. Then I would like the programe to respond...
My current configuration consists of Cisco ASA 5510 firewall. 192.168.1.254
layer 3 switch Dell Powerconnect 6248 which I am using as the main router 192.168.1.1
Cisco 1130AP 192.168.1.30
I'm dealing with a very small office that has 3 computers that have to connect to the network wirelessly. They also have guests that come in occasionally that need wirless internet access. I...
Hi, i am maintaining a simple network but i am having a problem with my DHCP, to give you a picture we are on cable internet piped thru a wireless Belkin F5D8236-4v1(01) down to a server runni...
I am fairly new to cisco wireless device, but I am trying to setup two cisco aironet 1250 APs so that clients can roam between them seamlessly on the same SSID. I do not have any external auth...
