Time for your 3rd Quarter Update! Are you in the running for the 6th Annual Expert Awards? Click the link to find out.
Third Quarter Hot Shots
Time Tested Wireless Solutions: 451 - 475 of 610
How can I bridge a linksys WRT54G to a WRT150N.  I have the standard linksys firmware on the 150N, and DD-WRT on the 54G.  I am attempting to wirelessly connect the 2 routers, then plug a gami...
I have a network setup that has a main office and 2 remote buildings included. In the main office building there is a Dlink 624 router with an external antenna. At each of the remote sites the...
I asking for opinions on the Wireless access points with the following. 1.  Offers very good throughput for 10 to 15 users. 2.  Supports the latest protocols and security 3.  Easy to depl...
Hi I have a linksys wireless router at home and recently I created extra layer of security by adding WPA enabled and connected my laptop, I also recenly got laptop which has windows XP and ...
It's a complicated problem but I will try to explain it. I have a WIFI account in a foreign country in a small village setup in my apartment. I have an older laptop here left on all the tim...
I am trying to set up a Mobile Sprint Broadband Card to become as my home internet. I have set up internet connection sharing on my machine to the card.  I have my computer plugged in to my...
Hi - I have a customer that currently has a dedicated server running Cisco WCS 4.2.62.0.  As part of a larger project I will be helping them migrate it to different hardware.   I have ne...
Hi, I've been researched wireless APs, and I'm having trouble finding a solid WAP that allows for RADIUS authentication against Active Directory.  I've contacted Cisco directly regarding th...
IBM Laptop  used at home. I always have excellent at 11.0 mbps. Use wep. Maybe 3 times a day I get the limited or no connectivity. I do a repair and it comes right back to normal. Using Acti...
We've got a client with LAN using a NETGEAR WG614v7 router via VIRGIN internet. When I called to repair a PC I noticed a new HP VISTA laptop lying with a NETGEAR w/l adaptor plugged in so was ...
I have an GSM Mobile device( Siemens c-35) attached to serial COM port 2 of my PC running win-2000 workstation. I have Created an SMS Gateway component using VC++ , any client application can...
hi, im doing an sms project using VB. Anyone know how to receieve incoming SMS in VB? Any code available? anyway im plan to use Nokia 8250 data cable in order to receive sms .
how can i implement sms gateway.Actually i want to send sms through my application globally. i donot want to use smtp.Can any one guide me. how to implement that .                      regard...
Im having issues roaming with my Broadcom 4322 AG card.  After running a debug on my controller I am seeing unsupported CCX version.  This is causing major problems roaming between APs. Has an...
Greetings, I am looking for a wireless router or router that allows me to connect to my home pc's remotely. I currently have a linksys wireless router and it does not allow me to do this re...
I'm using a D-Link DWL-G700AP.  I've chosen a Hawking HAO14SDP antenna.  My question is, how long of a cable must I install before I begin to lose signal strength? I need it to be 50'.  Thanks.
Equipment: NetGear Wireless Router and Zoom Cable Modem.   Ethernet cable connected between laptop and one of the four  LAN ports of the router. Ethernet cable  connected between modem and I...
Hi everyone, I am doing a feasibility study for a company that wants to install full wireless in a building that houses 1500 people. I have chosen to go with ruckus wireless, but my questio...
Hi, I'm looking for converter from .GIF to .OTB (over the air bitmap) It'll be nice if solution will be JAVA class Thanks in advance
Hi! What is the best way to identify a handheld device from a wap page written in ASP? By getting the IMEI number or is there any other way? I am currently getting the IMEI from the head...
i have uploaded the .jad and .jar files of the game but whenever i try to download it it will give me a file format unknown attach below is my source code <?xml version="1.0" encoding="...
All of sudden, Vista won't save my wireless network auto log on. After every boot, I have to choose my wireless network despite checking "Save this network" and "Start this connection autom...
Hey Experts, Thank you in advance for taking the time to help with this issue. Issue: Existing internet on 4th floor of old mill building (brick walls everywhere, with a central elevator...
I need to implement a wireless network over a large home.  I am considering a Sonicwall TZ210 and 4-8 sonicpoint N's.   Does that work as a good combo?  Can the TZ210 run multimple sonicpoints...
I have a router set up that has been working fine.   There is a messsage that comes up when I boot up my computer that previously (even with my router installed ) just said "HP wirless wan"...
