I have a Dell laptop with XP Pro. I am connecting to a domain through our wireless network.
I am having a problem where the user can log on before the network is established. This only hap...
I have a Lenovo T61 using an Intel 4965AGN Wireless card , IntelPRO set to manage the connections and a CISCO 1252 A/G/N AP. I can't get them to conenct using N, but it will work fine using ...
We purchased a Cisco 1252 Access Point. Unfortunately we made the error of purchasing the Lightweight LWAPP edition. The exact model number is: AIR-LAP1252AG-A-K9 We do not have a wireless...
Dear Sir,
i have linksys WAG325N V2-ANNEX a , i want to update its firmware , how should i do it and from where should i get updated firmwere .
kindly advice
I just downgraded my Toshiba Satellite laptop A205-S5804 from Vista to XP. I jumped through hoops just getting the install, many thanks to this site for the help. Now my laptop can't look for ...
I want to develop a program or web site such that when the user enters the country code and his/her mobile phone number, the program/web site will display the mobile operator accurat...
Hello, I am a newbe in J2ME and Bluetooth. I am trying to run an example I found on the net , but not successfull!! And I am getting frustrated because I need to establish a connection via blu...
I wanted to know if I coule upgrade my Belkin G Wireless Router to DD-WRT firmware. The reason I want to do this is because I want to connect my FTA box to a physical ethernet conn...
Hi Experts,
I have a Sony VIAO VGN-SZ200 SERIES which i'm having a problem staying connected to the wireless router. I configured it and it works for 30 or 10 or an hour , but then all ...
Does anyone know of any models of wireless router that support AP client mode? I'm thinking something in the home/home office price range. I currently have a TP-Link TL-WA501G that supports ...
Hi there,
I'm trying to configure a Cisco 1131AG Access Point with dual SSIDs. SSID1 -> INTERNAL should allow users to access network resources, while SSID2 - GUEST should only allow guests ...
I am a beginner in J2ME.
May I know how to use the Alert ? How to construct it and how to use it?
I have a motorola rzr and am having problems downloading the photos to my computer. I used an app call motorola mobile phone tools but it stopped working ... it also gives me a message...
Hi, I am trying to link two wireless access point so as to increase the coverage. I have problem in doing this . Do I have to use one as a repeater or as wireless client. I will appreciate a s...
A while back when I was using Windows XP I remember there was this really neat feature in windows where I could enter all the information needed in order for a computer to connect to my wirele...
I have a home network setup with 2 PCs and a laptop, 1 PC (running XP Along with Laptop) The WINXP machines are running rine no connection problems. The Machine running on Vista Will not conne...
Hello
I am bridging two Ethernet interfaces which have a number of vlans running over them. I want to be able to set up a destination nat for addresses in an address-list.
At first I did n...
Recently got Cisco ASA5505 with Aironet 1130AG as replacement to our existing RV042 / WAP54G. Net to Cisco equipment in general, had some hard time to set basic things on ASA and fin...
I am trying to connect to a Netgear Wireless Cable Modem Gateway CG814WG v2 and I do not know the password to use to connect to it and nor the encryption type. I am connecting from a MacBook ...
I am having a lot of trouble trying to get a Cisco Aironet 1130AG access point to work and I am wondering if it is possible to add a 1130AG to my network which is not using a Cisco LAN control...
I have Vista 64 Business and Intel 5300 AGN wireless on a Dell laptop. I can connect to my wireless network just fine, but get disconnected every couple hours to every couple days. Haven't s...
WinXP media ctr edition 2002, SP2, Dell Dimension desktop, P4
Use dialup connection (live in the boonies) for internet and email; bought a UTStarcom UM150 USB wirless internet modem today fro...
hi there.
Can anyone show me the commands for sending sms using Visual bASic?
I have done the mscomm.
using a Siemens mobile phone.
I am writing a program to check wireless connection by java. Would you tell me how to get SSID and Access point name which my laptop currently connect to?
I use Linksys wireless adapte...
I have a client who just got a Sony Vaio laptop with Vista Business. I use "gotomypc.com" to connect to her system remotely. The computer runs very well when plugged into the wireless router ...
