What do you think about Windows 7? Write a review or a how-to about Microsoft's newest product and earn unlimited points!
Time Tested Wireless Solutions: 476 - 500 of 610
Hi, We have a Small Business server that has had the admin password changed, and now no one knows what the password is! Is there a way of resetting the password? it's running on VMware if th...
I just recently moved into a house and Verizon has setup fios (fiber optic) with a modem/router combo on the main floor. I get good reception in the house, I have a desktop computer downstairs...
I am getting this message and don't know how to sort it out - whilst ensuring that I do not lose the conneection that I have. ( I am away from home in a foreign coutry.. Currently I am using a...
Dear Experts I need to create a sql view from data I have in a table called property.  The problem I am having is that I need to include some additional colums which are not in the property...
I'm trying to connect to an AT&T Wifi network in downtown St. Louis, MO.  I've used this connection many times before.  Signal strength is good, and I have been issued an IP address.  Everytim...
Could someone please tell me how to configure the siemens TC35 MC35 Terminal in suse. What drivers do i need?? And instructions as well. Thanks
Hi I have a program written in Wireless Markup Language (WML) but dont know how to run it. Can somebody help me please. Thanks aja
I can't see my network printer from one laptop. The other sees it no problem. I can ping it from one but not the other. Both laptops are XPPro wireless and the printer is connected via a wire...
travel some and need good wi-fi antennafor laptop. would like high gain and not too many extra connectors needed to make it work. http://www.cantenna.com/ is one i found with search. all help ...
Hi all I have a GSM Modem  and I want to get my SMS onto my laptop when someone sneds me.  How can I configure this. ANd is there any java codes to do it?? Whta is the whole actual proce...
I'm dealing with a very small office that has 3 computers that have to connect to the network wirelessly.  They also have guests that come in occasionally that need wirless internet access.  I...
I have  to configure a wireless network to provide access to GUEST users. I am searching for a way to provide access to my guest users though an access gateway, which will show a web page whe...
I have a lenovo T61 laptop that keeps dropping the wireless connection. I have searched the web and tried different things like using a different wireless card than the internal one and I stil...
Have 2 DLink 7700 AP - the bridge was functioning, a little slow - installed ANT24-0800 antennas, working, then dropped connection, they still see each other, error code=1, deauth parital log...
I have 3 sites (let's call them Sites 1a, 2a, 2b).  They were connected by T1 circuits, but were recently converted to Metro-E.  Everything works great, except for when I copy files.  Normal t...
What weather factors will effect wireless 802.11 connections? Such as rain, fog, lighting, event terrain, birds? If you could explain the science behind this, RF interference caused by weather...
We are going to setup the WLAN using CISCO 1131 AP and 4404 WLAN controller. The LAN private IP is 10.68.0.0/16 and we plan to use range 192.168.0.0/16 for WLAN. According to company policy, t...
Here is one for the stats nuts among us. I am trying to work out a way to find a theoretical laptime at a go karting event I am running. A great lap is 40.5 seconds but the heavier drivers...
hi I use a lap top daily with wireless lan to connect to the office network. Each day I have to remap my network drives after powing down th laptop each evening. When mapping the drives I a...
I am currently doing my final year project which requires me to develop some form of a Java application for handphones. Im thinking of making a J2ME application that can, via the handphones IR...
Hi, I will be working on a program for an HP iPAQ 2210 that will connect with a cell phone to send an SMS.  I am having trouble with the CMGS command.  After the AT+CMGS=# <CR> command, whatev...
Hi,        Can the Winsock Control in eVB 3.0 support wireless programing for pocket PC?? If it suport, can  I know of some links/sites that indicate this or show me how??? Thanks
I have been studying / developing some simple J2ME applications for past 1 month and have managed to built up a small application. This application uses Bluetooth as the underlying communicat...
i am trying to get ssid ... signal strength is working fine but ssid is giving me some problems... Can anyone go through this code and find what is wrong with it.. i get error like -------...
SMS
Hi, is there any way to send a text message to a rogers cell phone using 10digitnumber@pcs.rogers.com, such that they don't have to reply 'READ' to view the message?  Basically, I want to know...
