I changed out our Linksys AP's (that worked) for a new wireless system of a Motorla WS2000 and AP300 access ports. Ever since I swapped made the swap the wireless clients have issues getting ...
Hello folks,
I do a bit of work on the side and I visited a house yesterday which has been having on going issues with their setup and I'm hoping someone may have some ideas regarding an is...
Hi Experts,
I'm trying to add an access point to my BTHomHub2 (the new black with wireless N capabilities) to extend the signal to my garage.
Anyhow - I'm a little confused as to how it's su...
I have a new D-link 3200AP access point I want to configure for my building. .
My network uses static Class B IPs with no DHCP. So my plan was to give the AP a static public IP and use it'...
I am trying to configure a Cisco 521 Wireless Express with WPA and MAC address filtering. I have finally got the WPA to work, but when I add MAC addresses to the Local List uner Advanced Secu...
I need to design a wireless LAN with multiple VLANs. Plan to use all Cisco equipment and need a list of equipment and suggestions.
Wired LAN will also have multiple VLANs which should be ove...
Why is CDP showing a domain of cisco.com on APs connected to my switch? There is no "ip domain-name" configured on these controller-based APs. APs have been rebooted since final download fro...
Hi friends !
I want to start an Internet Café. I am planning to deploy 20 computers
I have purchased Dell Optiplex GX270 (Pentium 4 CPU, 20 GB HDD and 512 MB RAM with Windows XP Profess...
Hello
I have a Linksys wireless rotuer 600N with dual band. I am using the 3rd party firmware DD-WRT for this router. Although this new firmware improved my routers performance, Im still not ...
Hi. I re-installed my laptop for my son to use and it's ready to go except that I would like to get it connected to the internet. This is not my area of expertise and I am not sure if I can ...
I'm working on expanding coverage for a wireless network in an apartment building. The building is 8 floors with 12 apartments per floor, the basic shape of the building is a rectangle. I'm ...
I'm using a DLink Dir-615 Revision C Firmware 3.01. I'm curious about the MAC filtering option on the router. Does anyone know if the MAC filtering is just for wireless, or is it tied to the w...
i am using internet through lan on my laptop. Can i create wireless network for sharing of internet, if yes pls guide how.
hi all,
i was just wondering what debugs i can run to view wireless clients trying to connect to the network
I have engineers with notebooks that need to be able to access our network from all 40 stories. I am looking for some type of commercial product that will enable me to do this, if not, I guess...
I am in the process of straightening out the wiring on our switches and came accross an interesting problem with our wifi access points. Our network consists of 200 workstations, 10...
Dear Sir ,
i have a 500 GB harddisk at home and we have around 5 laptops working wirelessly , i want to share this harddisk wirelessly or any other measures through which i can...
I want to implement 3 Wireless Acess Points (not all identical) in our building.
I will set them to have the same SSID, WEP Security and Security Key.
I have read over 802.11r & 802.11k,...
I would like some advice on how to secure a Wireless network in my company. We have around 30 external users coming in next week with laptops all connecting to a new D-Link Wireless acce...
My daughters desk top pc (XP) used to connect wirelessly, no problem, to our BT Hub until I had to completely reset the hub owing to a fault. As a result the desk top pc no longer connects to ...
My Dell server seems to boot but no display amber light is showing instead of normal green power light
Small home/office network. One PC cabled to Belkin pre-N router and four PCs and laptops (mixture of XP and Vista) connected via wifi (WEP only). All working happily until new Sony SR39XN lapt...
My wireless router/the access point is attached to a machine that has Ubuntu installed in it. The other laptop machine that has Windows, always looses connection for no reason and get connecte...
I have a CompUSA wireless router (with four port hub) and a Belking wireless PCI card in my computer. For the last 5 months it has all worked well and then suddenly last month I found that al...
Can anyone tell me how to connect a java application with a MIDlet. The MIDlet interacts with a virtual phone and the app. interacts with a database.
