This is my MIDlet class. I have 4 lists. In the first screen I want to display the first list. When a user selects an option in the first list, the second list is to be displayed. Here ag...
Hello Experts,
I have no idea of working on Mobile Applications but has got a requirement from the client, where I have to facilitate the mobile user to upload a picture from his/her mobile...
Hi experts, I'm not sure I'm sending this Q in the right area or not.
I need an application (if free, it would be better) that autoanswers incoming phone calls from a certain number that work...
I'm working on a J2ME game where players are instructed to take a picture of something red (blue, yellow, etc) with their cameraphone. The program then evaluates the image in order to determin...
Hi, I have a wireless network set up at home. I am using a desktop computer hard wired into a D-Link Wireless ADSL 2+ Router, and a Compaq laptop using a Belkin G+ Notebook Card. Both computer...
Does any one know of a way I can set up a wireless Color laser printer. I need to put a color laser printer in a small area that has no wired connections. There is a wireless network already...
My client has a BES implemented, now one of the employees keeps on having sync'ing porblems. Sometimes his organizer does not sync, contacts also do not sync, also he has problems receiving ma...
Research has led me to understand that a WPA-PSK and MAC filtering are mutually exclusive on a Cisco Aironet 1100. I believe its possible to implement WEP and MAC filtering in conjunction wit...
I have a Linksys WRT54G that I have installed DD-WRT on. I disabled DHCP on the router and I changed its local IP to 192.168.1.1. However now when i try to punch this into my browser the brows...
We have a new laptop with Vista that will not connect with our HP 1100A printer on our wireless network. We have had NO problems connecting other computers and laptops with Windows XP, 2000, M...
my screen saver is not comming up when connected with wireless mouse.
But it is working with wired mouse.
what could the reason
Hi All,
I have been tasked to implement a new wireless Lan for our office which is housed in an old Warehouse.
I therefore need a high quality, reliable solution and Ideally looking to use C...
I will be installing a wireless network for a four-story, 61-unit apartment building. I've completed a site survey and decided I need 10 access points. The Internet connection is provided by t...
Hi All,
We currently use iPass for all our clients to connect remotely via a wireless connection (either at home or away from the office).
We've recently upgraded our clients to the late...
I have a Linksys wireless router that I use once or twice a year when the kids come to visit. I couldn't remember the router password so I restored the factory settings and reinstalled.
The...
What I am trying to do:
Implement a wireless network from Building A to Building B.
The two sites are 1600 feet from one another, I have direct line of sight with absolutely no objects i...
I need a Bluetooth headset (stereo) to work with a Dell 1720 laptop.
It would be a plus if it also worked with a Nokia mobile phone.
In every review I've found for the most common brands a...
i installed suse linux and it installed ok but now trying to get in connected to teh internet through my wireless. there is a wirless button on teh front but when i push it it still does not g...
installed netgear wireless usb hub software. says its installed. cant find wireless connection in control panel under network connections
Hi Experts,
I'm going to format my dell notebook. Anyway, I have not been in touch with latest IT development for years. I afraid after I format my notebook, how can I install the Intel Pr...
Wireless configuration Incorrect MFC Dll versions installed on the system
I've got an XP pc that's got a Dynamode USB adaptor installed and it just won't connect properly to my wireless ADSL router. Or more to the point it connects, then practically straight away it...
I have a Dell D420 with Windows XP PRO sp2 laptop.
This computer is in a AD used for testing GPO, now Im testing the Windows Wireless GPO.
Windows Wireless GPO is configured to use WP...
This ap was purchased to function as a standalone access point for use on out network, It it possible to run this by itself without a cisco lwapp or whatever it is?
Hello All!
I'm trying to setup Wifi roaming. I have 2 routers from Linksys. One is a WRT300n and the other one is a WRT56GC. Both of them work. This is what I did.
Same SSID
Channel...
