I have linksys wireless router WRT160N. I tried to upgrade its firmware but resulted in down grading it from 1.53.x to 1.0.2. ?I searched linksys web site and they have only version 1.0 (1.0.2...
I've been searching without success for a recommended configuration for Cisco access points that will support WPA2 without the need of an external Radius or similar service, and also support a...
I have a TC35 GSM modem to make calls to other GSM modems.
I am trying ATD command and always get NO CARRIER
- PIN is ok
- AT+CQS gives correct telecom
I also get NO CARRIER with ATA...
I have a Cisco AIR-AP1131AG-A-K9 wireless access point. This AP is an autonomous (stand alone) AP not used with a wireless controller. I used Cisco's upgrade tool & the correct image to upgrad...
I have recently started to have issues with connecting via wireless from my computer. For some reason I can see my wireless connection but am unable to connect even though the router is merely...
Hi.
When I connect to the internet using a DLINK DIR 655 router this message bubble appears
"windows was unable to find a certificate to log you to the network dlink"
I am still able to...
I need help creating a calculation in Access. This calculation is the sum of money to be received if & when certain targets are met. The reason why I want to use Access is because that is wher...
My boss brought me a wireless router from home to setup.
I did that a few times already and usually had no problem, but this one I am going to step on in a second.....
First I would like t...
Ok, I just got off the phone with Linksys tech support and I am not believing what they said. Here's the back story:
I just upgraded my cable internet connection to a speed of 15Mbps downl...
I'm trying to configure a Cisco Aironet 1130AG access point with WPA2. The AP is currently configured with WEP encryption, and we are wanting to move to WPA2. I'm trying to find some informa...
Computer freezes when running the adaptor. I've got Windows XP Home Edition, version 2002, service pack 3. The windows firewall is on. The router is a BT Home Hub.
I followed Belkin Support...
I am installing a Verizon Air Card 5220 onto my DELL laptop. I installed the software portion of install successfully. When it prompts me to insert card, XP does not recognize the card.
De...
I need to setup a RADIUS server for the wireless authentication and have no idea where to begin, even after reading http://www.windowsnetworking.com/kbase/WindowsTips/Windows2000/AdminTips/Sec...
Ive gone to Xp and theres a long list of Drivers under "network" 22 to be exact.
Anyone know?
Does anyone know of any wireless routers that will setup an unsecure wifi but when the user connects they must log in(e-mail and password) to access the internet just like many coffee shops ha...
I have a Cisco 1130AG access point that is currently running WEP security. Our company wants to migrate to WPA2 and what I would like to do is run 2 seperate SSID's... one with WEP and the o...
I've dell inspiron laptop which has a dell wireless 1395 wlan card.The os is windows vista basic.How can i enable monitoring/promiscuous mode in this card?
i make program to basetobase converter with (J2ME)
i want to make jar and jad file in order to be work in mobile phone
u can download the application from
http://www...
Hi! I need to extend my wireless signal from one house to another maybe 300-400 meters apart. At present I can get a very weak signal in the middle and top floors near the windows.
My route...
Hello Everyone,
I am in the process of converting our office's wireless network to use 802.1x access control. I have everything set up and we are successfully connecting and using the ne...
Hello, All...
Am trying to troubleshoot printing issue for a neighbor. Don't have the PC or printer in front of me now, so pls. forgive in advance, if I forget to give any necessary info. ...
I tried up update the firmware on a Cisco Aironet 1121G WAP and now I can't connect to it. I tried to console in but had on luck. I've searched the web on how to reset it to factory defaults b...
Hey experts,
I have configured by my mobile phone (Nokia 6600) to have a WAP connection by my WSP, and I put a WML file (actually an HTML file with WML tags) in the root folder of the IIS,...
I am trying to configure my router (Cisco 877w) for wireless access using WPA for security so that I can enter a simple pass phrase into the Windows Wireless Connection and gain access to the ...
