Do you know guys what to do to have a wireless internet on AA1 with new Ubuntu 9.04?
Ok, I've seen this done at hotels... Whenever you access the router via wireless signal it automatically redirects you to a certain web page when you open your browser. Does anybody know how t...
I am running my ADSL connection via BT Home Hub. I have 3 laptops that connect wirlessly via WPA-PSK to get internet access. Occasionally I do some ad-hoc sharing of folders with passwords to...
I'm new to j2me, i want to know is't possible to use j2me application to access to the mobile phone's address book?
E.g.
My application is a sms similar program then the program need to acce...
Sometimes users get the message attempting to authenticate.
We are using a Wireless Security Switch, with accesspoints connected to it. behalve that there is a IAS server and a Certificate ...
I have a mobile broadband USB card (novatel USB760), vista 64 business, on a laptop. If I use my wireless broadband card for internet access, everything works just fine. however, if I try to ...
I would like to convert my built-in wifi adapter to a wireless access point so that other users can connect to my wifi adapter as wireless AP.
Is it possible ? any ideas.
DearExperts,
I have a small size Wireless network which I used with my VSAT connection till date. I encounter a challenge when my organization decides to install WIndows 2003 server software ...
I'm going to be allowing a neighbor to use my wireless network. I want to set them up such that they can get to the Internet but cannot access any part of my LAN (printers, file servers, othe...
I have a client who has just bought a Dell P.C with windows Vista home premium. He also bought a DLINK DSL 2640B wireless router which came with a wireless USB adaptor. I set the router up f...
Hi!
See, I have this problem that I have to fix very soon. I'm working as an IT-technician in a small business.
Yesterdays (and todays) problem is that I must fix a laptop which can't connec...
Here is the scernio have a HP Officejet 6500 E709 that has wireless capabilities but i want to set it up ad hoc. Reading through the booklet it says it can be done. You set up the "network" of...
We have recently install 4 Cisco 5500 Series WLC's. We are trying to setup Windows 2008R2 NPS for radius authentication. In the servers event logs we are constanly recieving this message "A ...
Hi all,
How can i send automated SMS just like automated emails from the server or whatever??
I'm looking for feed back on different wireless captive portals that people have implemented / used / administered. I'm mainly looking for usage tracking and displaying and agreeing to terms ...
Hi Everyone:
I have a Linksys 802.11 G Wireless Broadband Connection setup at home. Basically, the DSL Modem is connected to the wireless router which is connected to the main compu...
Hi
I am using Sky Broadband and hence their provided wireless router to connect internet. I have two laptops (acer 5633wlmi windows xp pro and lenovo n200 vista ultimate).
I connect usin...
Hi all,
When I use ATD98765432 to make a call with my SIM card, I receive NO CARRIER. However, when I use my friend's SIM card, it works! Can anyone tell me why? Would it be the difference ...
Friend called out this laptop - I think he is saying "NC" 6000
He is having wireless issues and Im thinking I better have the drivers ready.
I have a problem in wireless coverage in my flat. I have purchased linksys wireless-G (wag354g) adsl gateway which I later replaced with wireless-N broadband router (model wrt160n).
Can I s...
I have a small network, with three Win XP Pro computers, one Vista computer, a Linksys Network Storage Link with two drives, and a couple of wireless drives. Everything has static IP addresse...
Hello. I have 2 Laptops (built in wireless) and a desktop (wireless PCI) and have just switched to BT
They have supplied me with a Home Hub 2. For the life of me i cannot get any system to ac...
Fellow Experts,
I have a D-Link DWL-800AP+ wireless access point/range extender that I used to use as a range extender, and now I would like to do so again, but I have lost the documentatio...
We have several Laptops that we have deployed in vehicles that have wireless access to our network. We also have EVDO modems installed on these laptops. The logic is they would use our wire...
I have 2 Cisco Aironet 1300. 1st is setup for root-bridge and the 2nd is setup for non-root bridge. I use a test QCheck to test the throughtput and I'm only getting 3 mbps. Should I be getting...
