2000 organizations, including eBay, Ericsson, and Lockheed Martin, now work smarter with Corporate Accounts. Save over 36%!
Time Tested Wireless Solutions: 126 - 150 of 603
I upgraded from xp home edition media center to XP Professional. Now my internal wireless device cannot be found nor loaded (from HP website) nor does the wireless assistant work after the OS ...
I have two Fujitsu - Siemens laptops identical which are wireless and a desktop with a wireless router (Baudtec TW263R4 wireless router) all running XP. I have been able to connect one laptop ...
I have a Acer Aspire 5720G, I've had it for 2.5 years. All of a sudden the wireless stopped working. When I go into eNet Management it says I have no wireless device installed. When I go to de...
Is it possible to create a simple text to speechapplication for windows ce using .NET Compact Framework OR Embedded Visual Basic. I have SAPI 5.1 Installed on my computer which I am successful...
Dear EE users, I know that with WPA and WPA2-PSK I have to enter a pre shared key (simple password) in order to connect to the network. But what is WPA and WPA2-enterprise? As I know it is ...
I am looking for a code which can help me in reading RSSI (signal strenght) from local Access Points. I have to use Windows XP Service Pack 2 as O.S. with Native Wifi libreries (these are th...
I have a Mikrotik wireless bridge with a cisco switch on each end...each cisco port is configured as a trunk port, but vlan tagged traffic still can't pass between the two switches....other no...
System: Windows XP SP 2 client, domain joined Authentication through RADIUS server Error on WLC: Received EAPOL-key message while in invalid state (0) On Client:  Works for a while, the...
Hi i'm new to J2ME programming. I have installed the wireless Toolkit 2.2 (C:\WTK22) and also have the JDK 1.5 (C:\Program Files\Java\jdk1.5.0_04) installed on my pc. I do have sample MIDlet c...
Dear Experts, I have a local network consisting of 4 PCs connected into a switch. I have a Cisco Aironet Wireless Access Point connected to my main router. What hardware do I need to ...
hi guys! i'm developing an application (school project) that will send and receive SMS message from a PC to a mobile phone and vice-versa. I have a GSM modem. I have to use Visual Basic 6 a...
I've got a weird situation that I haven't been able to figure out.  I've got a new Gateway laptop model MT6840 running Windows Vista Home Premium.  This is the only computer in the home networ...
I am having issues configuring the AIR Card 595 from Sprint with The DIR-450 Router. The router is at the most recent firmware v.1.03 and Hardware Revision A1. This is the router: http://...
Hi, I am trying to create a custom login page following Ciscos instructions but have hit a wall :(  I have created the web pages I want and have packaged them up using tar compression as pe...
  Unless I am doing something incredibly stupid (which has been known to happen) I find the range of 802.11n in the 5GHz band so limiting it is almost useless either indoor or outdoor. So the...
Currently have a PC with XP SP2 and a Linksys wireless card.  don't know if it is related but I installed AVG antivirus and anti spyware on the machine.  About a week later, I experienced seve...
I require a Web Server (template) certificate for my Cisco 2106 WLAN controller however the controller cannot directly request a certificate from the authority server and I cannot create a Web...
I have a Cisco AP1100 with one SSID and puts all users onto VLAN 1of the 2950 switch to which it is connected.  I would like to create a guest VLAN that would put guests onto another VLAN - sa...
About 4 months ago, I replace a faulty Cisco Aironet 350 Series Bridges with a Cisco Aironet 1200 Series Access Point as we had it at hand. We have two building about 60 metres apart and on...
Hi Everyone, I was wondering if there is a way for a user to enable and disable the wireless connection without local admin rights. I heard there is a registry key you can modify. anyone have...
I have a Compaq nx6110 notebook and it is wireless, but I am not able to turn on the wireless card. I am running Win Xp Pro. There is a button nert to the power button for the wireless card,...
Greetings, I'll try my best to describe the problem and provide enough information. Problem is: Numerous network disconnects when trying to access Microsoft Access Database's on a Serve...
Cisco 851w router.  Unable to setup wireless successfully.  Any guidance will be helpful. My pc is connected to the switch and it is working that way. However, cannot connect my laptop t...
Hi, I've recently configured a Cisco 877W with a mix of the CLI & SDM and everything currently appears to work ok, however wireless will work for a certain amount of time and then just stop...
Hi all have developed an SMS gateway using VB, mscomm and Wavecom GSM modems, that receives requests for data via SMS and sends a reply to requestor via SMS. however, now that my user lo...
