About 4 months ago, I replace a faulty Cisco Aironet 350 Series Bridges with a Cisco Aironet 1200 Series Access Point as we had it at hand.
We have two building about 60 metres apart and on...
I am setting up a secured wireless network connection. I have entered my network, made it the priority connection. However there is an unsecured connection that I have deleted it several times...
Dear EE experts,
What is the difference EXACTPLY between Open system + WEP and Preshared key + WEP?
Chris
I need to do the following:
- from a PC/Server send an SMS message to a phone (I will have the phone number)
- this SMS message must be sent to a specific port# on that phone (this enables...
I've got a weird situation that I haven't been able to figure out. I've got a new Gateway laptop model MT6840 running Windows Vista Home Premium. This is the only computer in the home networ...
Having purchased the router (Netgear Rangemax Next Wireless-N Router - WNR834B) I am having serious problems getting wi-fi to work. My old router was a Netgear also with 108m/bits. I had con...
Dear experts ,
i have brought HP OFFICEJET PRO, L7500/L7600/7700 printer kindly guide me how should i make its setup in WINDOWS vista bussiness version. kindly if poss...
I would like to broadcast both SSIDs configured on my 1231G. However, whenever I add the guest-mode command to an SSID, the other SSID loses their "guest-mode".
Is there a way to configure...
Anyone know the default management IP of a Motorola (Symbol) RFS6000 Wireless switch??
Trying to setup some demo kit and I'll be buggered if I can find this info in any of the documentation...
I need to have a web page query for the bssid or MAC address that the viewer is in and if they are using a specific BSSID or MAC address send them to a different part of the website. This ne...
Hi. I¨m currently trying to bulid a simple midlet to push whenever an incoming message is recieved through a socket at a given port. Only testing in the SonyEricsson WTK emulator at the moment...
I have Copier/Printer, it has USB support. What would be the best way to make this device wireless. I am seting up a classroom with 15 computer and all are wired. The copier/printer will no...
I'm using Kannel GW to send/receive SMS messages. The messages should be addressed to a certain 16-bit port, thus I'm trying to send the messages with the following UDH: "X-Kannel-UDH: 05040E0...
Hi!
I'am working on an application where I need
to decode a SMS message that is coded with PDU.
Is there anyone that can provide me with algoritm to
decode the message.
/Fredrik Nil...
My phone has been failing me and I have 60-days before I can renew my contract and get a 'special' deal on an overpriced phone, so I purchased one from e-bay to get me through the next couple ...
Can't get my laptop to find the belkin router. My laptop has a built in wireless card. When I scan for wireless connections It says there is none available. I'm only five feet from the router....
i NEED A SECURITY KEY OR PASS PHRASE FOR ALINKSYSROUTER,MODEL#wrt54gs
LINKSYS_SES_8624.cAN YOU HELP ME WITH THIS.
I have got a Linksys WET54G Ethernet Bridge to help boost my wireless throughout the house (Big old house with thick walls!) But I cannot even get past step 1!!!! I've connected the device dir...
Hi Everyone,
My wireless G on my Netgear WNDR3300 dual band N is not broadcasting. I have this issue with old one so I returned it to Netgear and they have just sent me a new router, the sa...
I have a wireless connection on a Dell laptop that was working fine until a few days ago. It is showing that I am connected wirelessly with an excellent speed and I can access my office termi...
Hi I have just bought a belkin G+ Mimo I want to make a wireless bridge with a belkin Wireless access point F5D7130 as i have just changed over to cable I had it set up before with my belkin m...
hi all. i have been develop a project of receiving and sending sms using data cable that connect phone to pc.
well...now i m doing my report...i have using the active-x control by software ca...
Hi - I have an HP iPAQ 111 with Windows Mobile 6.0 which bought a few weeks ago.
I have a Linksys WCG200 Wireless Cable Gateway which is secured using a 25-digit key and I do not broadca...
How can I Transfer Phone Data (contacts, messages, photos etc) from a Sony Ericsson phone to a Nokia phone?
Any ideas?
Alright, it seems I have a bit of a conundrum on my hands.
At my friends office, they have a wireless connection that they use to do their work. As of right now they have one desktop conne...
